Knocking at Low Rpms
Old Jun 13, 2005 | 10:46 AM
demetri's Avatar
I don't really know anything about this timing stuff,
but everytime I accelerate i hear this nasty knock. Im thinkin it has something to do with the timing. My dad told me I should retard the timing. I have no clue whatsover on changing timing. I have searched the forum but i cant find anything on timing. If anyone know my problem please tell me.
Old Jun 13, 2005 | 05:58 PM
demetri's Avatar
bump
Old Jun 13, 2005 | 06:38 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
what kind of gas are you using? Just using better gas could fix the problem. Also the timing is supposed to be at 0*. Mine is at 4*advanced and i get a few knocks. Just try better gas bro.
Old Jun 13, 2005 | 08:58 PM
sellmanb's Avatar
Car: '86 Berlinetta
Also, what weight oil are you using in the motor?
I've written atleast 3 explanations on how to check and adjust timing in this forum alone, I'm sure you'll be able to find atleast one of them
Old Jun 13, 2005 | 10:38 PM
demetri's Avatar
Im using 93 octane and synthetic 20W50 I got for free at Harley Davidson.
Old Jun 13, 2005 | 11:16 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Then i would look at the timming then. Remeber that your timming needes to be at 0*. Or you can to trail and error and see where your engine likes it at. Mine likes it at 4* advanced. After you adjust it, go for a drive to see if its still there. keep doing this till your happy with it. Good Luck
Old Jun 14, 2005 | 01:09 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Try oil that is designed for cars, not motorcylces. Time for an oil change.
Old Jun 14, 2005 | 07:42 AM
demetri's Avatar
Same thing, I mean what weight should I put in it? I mean its free!
Old Jun 14, 2005 | 11:26 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Free or not doesn't change the fact that it's still not a weight of oil that is designed for your engine. And it's hardly the "same thing."
Get 10w30.
Old Jun 14, 2005 | 01:19 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I would go 10W-40
Old Jun 14, 2005 | 01:51 PM
bstieboydp's Avatar
Car: 1987 camaro, 1994 z28
Engine: 2.8l V6 mpfi, 5.7l lt1 350
Transmission: 700r4 in the 2.8, and t-56 6-speed in the z28
i agree def change the oil motorcyle/car oil is not interchangeable well atleast not with great effect, and i would only use oil thats suited for your application i use 10w-40 myself.. its really a preference, as long as its within the limits of the manufacturers suggested weights, good lucK!
Old Jun 14, 2005 | 07:24 PM
demetri's Avatar
yea thats what my uncle said, but he said try 5W 40
Old Jun 15, 2005 | 10:33 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
How many miles does your car have? It all depends on that. IF your passed 50,000 miles then i would got into the 10's
Old Jun 15, 2005 | 01:31 PM
demetri's Avatar
its about 130,000 i think
Old Jun 15, 2005 | 07:02 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Im not sure if thats a good thing or what Just do an oil change and go from there. Remember 10W-40 Your choice of oil brand. I always go for Qacker State or Mobile 1 if my car is being good.
Old Jun 15, 2005 | 09:10 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
20W-50 works great in 305s or even 350s for that matter. It is the GM recommended oil in the 1983 owners manual for the climate I live in. I have this certain little feeling that the bottem end in my engine is identical to yours (except the 1 piece rear seal crank). The 1992 350 that I had was designed to use 20W-50 in this temperature too.
Old Jun 16, 2005 | 08:47 AM
demetri's Avatar
i have a feeling that If I change my oil to 10W40, it still won't fix the problem. My guess that over time, the timing chain has become stretched and changed the timing a little bit.
Old Jun 16, 2005 | 12:40 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
right, it may not fix the problem but he needs to put the right oil in there. You got to start somewhere.
jklein337
Sep 19, 2018 06:23 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Jake_92RS
Aug 17, 2015 09:42 AM
gwade12
Aug 8, 2015 08:17 AM
