160 Degree Thermo
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
160 Degree Thermo
Like the subject says....is this alright for a stock 305 TPI with just high performance cat and a flowmaster? My 180 degree went, so i got the 160, and got better results. Any input on this?
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
OTHER RIDE:
12/14 Options
Stock(for now)
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
from what i have heard a 160* thermostat is too cold for our cars (unless ECM has been reprogrammed to enter closed loop sooner). since the thermo opens at 160* it keeps the computer in open loop mode longer. thus a little more gas is used. A 180* would allow the computer to enter closed loop like it should.
88' IROC-Z, 350 TPI, 700-R4
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have had mine for years and I have no problems even with the stock chip in.
I know it goes into closed loop because I have checked it in field service mode.
Engine: 5.0 TPI
I have heard the same thing, i just wanted to double check. I went to pep boys, and they pulled it up on their computer-which thermostat's would work with my motor....the first two that came up were the 195 from the factory and the 160-thats what confused me-beacause i heard of the open loop mode. I couldnt find a 170 degree thermo that was for my car....maybe i will switch back to the 180. Thanks for your help.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
Keep her at 180-195. I put in the 160 and got very minor if any performance out of it. The motor obviously ran cooler, but I never really felt it. When it came time for emissions check...I was almost 4 times the limit...changed the stat...next day I passed. Just cuz I didn't beleive it I changed back to the 160...waited a day and again failed miserably. Makes ya wonder what effect this has on your cat?
Engine: 5.0 TPI
this would damage the cat???? If so, then i will have to go back to a 180...damnit....well, its just a pain in the @$$ to get to.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
Engine: 5.0 TPI
Yea...i agree....i'll do the switch this weekend probably...back to a new 180. I just wanted to make sure that it wouldnt hurt anything like my cat or anything else. Thanks.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
I don't actually know if it's bad for the cat, but it would seem that if there is that much extra emissions running through your/my exhaust system...it would shorten the life of the cat. Anyone know for sure?
Engine: 5.0 TPI
Yea, if anyone has any additional info on this, that would be great and much appreciated. Thanks.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
Engine: 5.0 TPI
Also, in relation to my 160 degree thermo, what is the temp reading right in the middle of the guage, between 100 degrees and 220? I am curious because that is where I am running 90% of the time now with the new thermo and my fan wired to a aux switch. Thankx.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
Car: 91 RS Convertible
Engine: 305 TBI
I figure it's right at 160 to 180 for the mark.
I'm running a 160° thermo for the past 3 years and have passed emissions each and every time.
If you have problems passing the sniffer with the 160° thermo, then turn on the a/c and let the car idle until it starts getting hot.
Or just disconnect the fan motor for a few minutes before arriving at the sniffer.
If there's a will there's a way.
Engine: 5.0 TPI
LOL, thanks for the useful info subitz
But thankfully, out here in PA they dont check emissions
Not yet, anyway.
OTHER RIDE:
12/14 Options
Stock(for now)
Not yet, anyway. ------------------
OTHER RIDE:
12/14 Options
Stock(for now)
RedLeader289
May 28, 2019 01:47 PM
