Wierd vibes...
Old Sep 9, 2001 | 11:02 PM
SgtSkip's Avatar
Wierd vibes...
I'm getting a strange vibration when I back down off the throttle at highway speeds. Seems to be there when I'm more coasting then not. Goes away as soon as I press down on the throttle a bit. You can feel what seems to be a harmonic vibration when going down a steep grade where the engine is basically at idle but you're still doing 65+. If this is an indication of comming problems I need to fix it ASAP before I deploy again.
85T/A 305/QJ work in progress.
Old Sep 10, 2001 | 03:31 PM
hilljackofdenile's Avatar
hey, i have the same problem. I have an 82 camaro z28. is it like when your accel. it feels fine but as you slow to about 65 or 60 the whole car starts to shudder? I still cant figure it out accept that people say that the older cars just do that. they said that the trany could be out of balance, but i dont think thats it since its not consistant with acceleration. Im sorry i havent figure this one out either but if I do, ill post again.
Old Sep 10, 2001 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Typically that is pinion bearings... can also be U-joints. It's not the kind of thing that means it's just about to die, it could go 100,000 more miles and just get slowly worse before it dies.
Try new U-joints first. While you have the driveshaft out, tighten the pinion nut if it's loose, see if that helps.
ICON Motorsports
Old Jan 14, 2002 | 12:37 PM
SgtSkip's Avatar
Just an update. Turned out to be a bad trannie mount.
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
Apeiron
Carburetors
Oct 18, 2001 04:54 AM
gruveb
Sep 29, 2001 03:06 PM
