87 Fuel pump options??
Old Jun 22, 2005 | 12:00 PM
Coda79's Avatar
Car: 87 Trans Am
Engine: 305 carb swap
Transmission: 700-r4
Hey new member, I've owned several 2nd gens and a 4th gen, but I finally got my hand on a 87 T/A 305 700R4. The car has had an earlier (80-86) 305 put in it, and in the middle of a carb swap a guy I know had to sell it, so I bought it. I noticed that it has a mechanical fuel pump already on it, so I guess my question is:
-Should I pull through the stock in-tank pump (not hooked up)?
- Should I pull out the in-tank pump?
I guess I'm not too familiar with this, I've only messed with mechanical (old) fuel systems and I just dont want to mess anything up.
Thanks in advance for any help.
Chad Boulden
Old Jun 22, 2005 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
The preferred set-up would be to have the in-tank operating and pushing to the mechanical. If you don't want to hook up the in-tank, the best bet is to remove it.
Old Jun 22, 2005 | 02:26 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
Originally posted by five7kid
Welcome aboard.
how does this work? my volvo has two pumps. wouldn't the electric pump mess up my holley mechanical?
Old Jun 23, 2005 | 10:19 AM
Coda79's Avatar
Car: 87 Trans Am
I'll have to see if the stock one is still pumping, if not, I've pulled 2nd gen gas tanks, any tricks/anything different pulling 3rd gens?
Old Jun 23, 2005 | 10:58 AM
five7kid's Avatar
Pulling a 3rd gen tank involves removing a lot of suspension stuff underneath it. But, it is still a pretty basic operation.
The fuel pressure should be regulated when using an unregulated electric in the back. The factory just let the return-style mechanical do that. If you have a non-return mechanical like a Holley, you need to use a return-style regulator after the mechanical - the reason for that is you don't want to dead-head the in-tank, because that will burn it out.
A pusher electric won't do any harm to a mechanical pump as long as the output is regulated with a return style reg.
Old Jun 23, 2005 | 11:34 AM
Coda79's Avatar
Car: 87 Trans Am
Thank you, that answered a lot of questions I had.
Guess I'll go pick up a return-style regulator and hopefully get this thing together for vacation next week.
Thanks again for all the help!
chad
Old Jun 23, 2005 | 01:49 PM
what's the advantage of doing it like that? would I install the return regulator before or after the mechanical pump?
Old Jun 23, 2005 | 02:33 PM
five7kid's Avatar
I suppose you could do it either way, but after the mechanical would give you adjustable pressure at the carb inlet.
Old Jun 23, 2005 | 02:54 PM
ok, so what's the advantage?
Old Jun 23, 2005 | 03:39 PM
five7kid's Avatar
You wouldn't be relying on whatever the mechanical puts out for the final pressure at the carb.
Old Jun 23, 2005 | 05:02 PM
then why bother with a mechanical pump at all then?
Old Jun 24, 2005 | 04:30 PM
Coda79's Avatar
Car: 87 Trans Am
This is speaking out of ignorance, but wouldn't it make more sense to put the regulator before the mechanical, so the fuel isnt hitting the mech. pump at a higher PSI (from the in-tank) and in theory wearing it out sooner, or is that not a problem.
chad
Old Jun 25, 2005 | 08:51 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
personally, since the car isn't running yet, just drop the tank and put a tube where the intank pump was and be done with it, or get a carb style intank sender like this,
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
