engine bogging on takeoff
Old Jun 22, 2005 | 02:18 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I have an 87 T/A with a 305 TPI. When I take off from a light or accelerate the motor bogs down & surges, it only does this when you give it 1/4 throttle or less. The engine takes off fine if you give it full throttle. It also bogs when you give it part throttle to maintain speed.
Anybody got any ideas.
Old Jun 22, 2005 | 11:20 PM
bstieboydp's Avatar
Car: 1987 camaro, 1994 z28
Engine: 2.8l V6 mpfi, 5.7l lt1 350
Transmission: 700r4 in the 2.8, and t-56 6-speed in the z28
im facing the same exact problem right now but with a 2.8 dwillis pointed me to the egr valve as he had similiar problems and that fixed his i will do the same you should give it a shot i think althought its alot easier to check out for you so def give it a shot just disconnect the vacuum going to the egr and plug if runs better then thats it i have to take off my plenum tho to check this out but definately worth it if it fixes it considering im car-less right now lol (relying on the ole 95 zx6r) good luck man
Old Jun 23, 2005 | 11:17 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I kind of thought the same thing. I am going to check it out today. I'll update what I find.
Thanks for the idea!!!
Old Jun 23, 2005 | 07:58 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
My friend had the same problem with his 87 IROC TPI, he plugged off the EGR and that thing ran like new.
Old Jun 25, 2005 | 03:21 PM
bstieboydp's Avatar
unfurtunately i tried plugging the egr with my finger but it still does the same thing, i did notice however that there is no vacuum on the egr is this normal? or should i replace it im so lost car still is off the road grrrr
Old Jun 26, 2005 | 08:58 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Are you plugging the EGR Valve itself or the line coming off the EGR valve?? Need to plug the line you pull off the EGR. Thats what he done and do you want to talk about a difference, it went from chugging and sputtering on easy take offs to running smooth and from sluggish hard take offs to tire smoking take offs.
Old Jul 1, 2005 | 07:29 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the responses. I found the problem the hard way, the fuel pump died!!! I will replace it this week & will be off & running. As for disconnecting the EGR instead of fixing it you can run into trouble. This can make your car run hot & cause driveability problems. Find out if it is the EGR valve itself or the selonoid. You can probably put vacuum on the EGR to see if it is working. You can put a vacuum guage on the line from the selonoid to check it.
Old Jul 1, 2005 | 08:24 AM
bstieboydp's Avatar
figured out my problem with ALOT of help from 8mike9, thanks again man, it turned out to be a short in my car alarm that the t00l who i bought the car from put on i disconnected everything that had to do with the alarm, and put new fuses where they blew, also tapped with a screwdriver on the egr solenoid (read on a forum somewhere this worked) and wala when i started my car all my troubles went away along with no more burnt up fuses, me so happy btwthanks guys for the replys
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Logan Bryant
Aug 27, 2015 11:52 AM
Out-Cast
Aug 17, 2015 10:57 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
