Anyone Know car alarms?
Old Sep 8, 2001 | 05:26 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I want to adjust the sensitivity on my alarm. The guy told me to just come back. But its kinda far. These Directions look easy enough dont they?
Only thing I dont know is what/where the "Valet" Switch is.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
Old Sep 9, 2001 | 05:27 AM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
under the steering column, by your feet, pull down the cover...i think it's 6 bolts, there should be a main control module with a torx bit somewhere on the box. clockwise is more sensitive, counter reduces. chances are, the sensor which controls vibration will be mounted on the left side on bare metal.
Old Sep 9, 2001 | 12:12 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Dont I have to use the remote to adjust sensitivity? All I see under the column is a box that says "Impact sensor" and it has no screws on it.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
Old Sep 11, 2001 | 05:26 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i guess i should ask what type of alarm it is. usually the remote will only deactivate and reactivate certain sensors such as vibration, height change, and glass but doesn't adjust sensitivity. you should have instructions with your alarm. i guess if you wanted to reduce sensitivity without an adjustment, you can change mounting positions for the sensor. if it's on metal, chances are it's quite sensitive, dismount and leave it hanging with the rest of the wires, you'll be covering them anyway.
i used to have mine set to where a single tap on the car would sound the warning, even a loud car driving by would set it off. finally, i had to break down and reduce it.
Old Sep 11, 2001 | 05:33 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
about your valet switch... this is just a normal switch usually mounted somewhere hidden. whoever installed yours might've left it out. i left mine out... how often do i use valet parking... no one drives my baby but me! this enables and disables the alarm and automatic shutdown yet still allows the remote to lock and unlock doors. if i remember correctly.
palestinians.... you're all dead
Old Sep 11, 2001 | 06:02 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I got it, thanks guys!
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
