Valves - size ?
Old Jun 23, 2005 | 11:31 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Valves - size ?
Hmmmm since my car's a daily driver (i.e. need to run wife around too *lol*) I can't strip the engine right now... so that's why I have this question
What's the specs for the intake and exhaust valves on a 305 TBI from a '91 Camaro RS ? ... i.e.. .. stem ... head diameter .. length etc
Reason I'm asking, I got valves in my garage that I bought a long time ago for my lil'hobby car (the '76 Fiat Spider), and the exhaust ones should work not sure about intake
I'd like to go a lil'bit bigger .. but.. basically just to the point where ya can install the valves by doing bigger 45 degree cuts and they'll fit in ... I don't want to overdo it
Old Jun 24, 2005 | 06:40 AM
ede's Avatar
ede
depending on the heads could be 1.5, 1.6, 1.84, 1.92. why don't you post what head you have, that would make it a lot easier. i'd guess there is about a zero chance the valves interchange and if the 10 dollar replacement cost of new valves is a problem maybe you should wait untill you had the jack for SBC valves.
Old Jun 24, 2005 | 03:31 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
ok
I believe it's a L03 engine .. that's what the '91 Camaro RS came with
Actually the valves could fit .. because they came from SBC's .. only way I could buy bigger valves for my project ... and then I was planning on having them recut for the Spider .. but now I may use some of them for the Camaro
Some are titanium, some are stainless
Old Jun 24, 2005 | 04:40 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
1.5" and 1.84" cam stock.
Old Jun 25, 2005 | 01:20 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Waow
Kewl .. I think mine are 1.6 lol ... means can cut them down
hmmm ok one of the most important questions.. what is.. the stem diameter ??
Old Jun 25, 2005 | 01:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
11/32" stems
Cutting them down will probably cost more than new valves.
Old Jun 25, 2005 | 10:33 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
kewl
Unless I can get one of my buddies in the Navy to do it lol
thanks for the specs
Old Jun 25, 2005 | 01:49 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Why don't you have the heads machined to fit the bigger valves instead. Your pretty much just wasting those valves, cutting them down.
Old Jun 25, 2005 | 03:20 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Well
I got them for not a bad price ... but problem is... gotta look at them again .. somewhere in the garage ... I think they may be 7 mm stem diameter ... too small
Old Jun 26, 2005 | 01:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
While you are Kluging it up, may as well have 7mm inserts installed too.
Old Jun 26, 2005 | 09:00 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What heads are these valves supposedly going into? What the casting number. If you wanted, you could just have the heads worked, to accept those valves. Then port them and you will have some nice heads.
Old Jun 26, 2005 | 09:06 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Never mind i just saw you have and LO3. Forget about those heads, they are junk. Find some 416 or 601 heads. Have them worked and ported to accept the valves. These heads would then be decent.
Have you measured the valve sizes yet? What valves are they again?
Old Jun 26, 2005 | 11:40 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
L03 heads
It's L03 heads, standard ... reason I mentioned those is I was just going to get a second set from the junkyard, rework them, portmatch, slight very slight work o nthe combustion chamber, sligthly different valves . .that's all ... nothing tremendous .. and keep those as running heads .. and the stock ones as a backup ...
416 or 601 heads hmmm are those 305 heads ?
Ya know folks .. ya by any chance got a url for hmm or something.. where I can see a list of good better and best heads for 305 engines .. and which cars they came in ?
Also I'll still need them heads to be somewhat smog heads
Old Jun 28, 2005 | 04:53 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Combustion chamber volume
L03 combustion chamber volume is hmmm 58 cc ? Or is it 64 ?
The heads from 305's from Camaro's earlier than '91, were they a better design ?
All I need is hmmm like hmmm a casting number ... or ... car/model/year good heads .. 305 heads.. came on.. and I can find it at a junkyard
Old Jun 28, 2005 | 11:14 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Get 081's, your intake will bolt on without mods...yes, 58cc's.
Old Jun 29, 2005 | 01:53 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
081's ok
OK.. is there a list of all the heads .. somewhere out there .. which cars they came on ? How to identify them ?
Old Jun 29, 2005 | 10:44 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You identify them by looking at the casting number.
www.mortec.com
Old Jun 29, 2005 | 01:58 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
thanks
Yeah I found that one yesterday . .was wodnering if there's other lists too... with CC numbers, bore size etc
Old Jun 29, 2005 | 02:03 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
ah ok
So this one would be a rather good choice
14022601...80-86...267/305......1.72"/1.5" or 1.84"/1.5" valves, 53cc chambers
Would raise the overall compression ratio slightly.. or if not at least leave room for combustion chamber work without drop in compression
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
