350desleeved into 400,Possible??
Old Jun 26, 2005 | 04:54 PM
phealinphine69's Avatar
im trying to find a 400sb and well, they;re pretty damn hard to find round here. could i take a 350, knock the sleeves(i think thats what they call the inner part of the cylinder, the part that actually gets machined) and i guess bore the actual block out and put some bigger sleeves in??thus creating a 400? if so where would i get the bigger sleeves? how much would it possibley cost??
one other quick question, i have an 88maro 2.8with a 5speed, it has a zoom clutch installed by previous owner, would this handle a 400sb's power? what kninda tranny is this anyways!!
Old Jun 26, 2005 | 05:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There aren't any sleeves in factory blocks. You'd have to bore the 350 block .125" over plus the size of the sleeve, which would be well into the water jackets. You'd end up having no metal left in the block to support the sleeve.
Old Jun 27, 2005 | 02:05 AM
454c's Avatar
The most CI I've seen out of a 350 block was something like a 392.It used a custom stroker crank which means big money.
Old Jun 27, 2005 | 02:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A .030 over 350 block with a 3.875" crank is a 396, those cranks aren't all that hard to get. If you could manage to fit a 4" crank into a 350 block you'd have a 402.
Old Jun 27, 2005 | 05:08 AM
ede's Avatar
ede
guess 400s aren't that hard to find if you look in the right places
Old Jun 27, 2005 | 06:39 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I know a guy sellin a 400 SBC 2 bolt cleaned bored +.030 cam bearings for like 450.. if ya want his name let me know.. and no that tranny would not hold up to a 400, the v8 version of that tranny barley holds up to a 305.
Old Jun 27, 2005 | 11:02 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I know a guy that has one to.
Old Jun 27, 2005 | 01:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Every morning I see a guy in the mirror that has one too.
Old Jun 27, 2005 | 04:02 PM
yea but i live in tampa,fl. first person was from NJ and then another from Indiana. shipping would be astronomical for a nearly 200lb object. mabye someone could do a lil hagglin for me
for real though, im dyin for one of these ,looking for the last severalmonths
Old Jun 27, 2005 | 06:19 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Ed (ede) lives in mississippi or somewhere downthere in the south.
Old Jun 27, 2005 | 08:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Wait a minute you live in tampa and cant find a 400? Water+boats+local boat shops=400's. Or you could just buy the 400 from ede.
Old Jun 27, 2005 | 09:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As mentioned above, there's not enough metal around the cylinders to install oversized sleeves. At about $100 per hole plus all the machining it would be cheaper to just buy a new block.
My 509 casting 400 block is collecting dust under a bench in my garage. Since I've gone to BBC, I have no need to build a SBC at this time. I'm sure I could sell it quickly if I ever offered it up for sale.
Old Jun 27, 2005 | 09:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Let me know if you do.
Old Jun 28, 2005 | 03:46 AM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
who in indiana or ohio has a 400 block?
Old Jun 28, 2005 | 04:10 AM
i hope ed reads this again cause he doesn't except e-mails and i dont know how reliable the PM thing is since im new to the site. but if your still aroundede, phealinphine69@yahoo.com gladly discuss business with ya.
and no....all marine applications seem to want to use 454, least everywhere i've check, which is bout the entire tampa bay
Old Jun 29, 2005 | 08:25 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Some rag about 5 or 7 years ago got one out to a 454.
Ummm, no, I don't think so, a bit north of that in fact last I heard.
i hope ed reads this again cause he doesn't except e-mails ...
But he sure does *accept* PMs. Try the little button on his post that says... 'PM'
Old Jun 29, 2005 | 07:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The 454 SBC doesn't use a factory production block. The aftermarket blocks have thicker cylinder walls and allow for larger overbores. The 434 package is becoming very popular but the 454 SBC is taking it to the extream just to show it could be done. Trouble with these large SBC engines is that you need to spend big bucks on heads large enough to flow enough air to feed them. Big SBC heads are usually where small BBC heads start.
Old Jun 30, 2005 | 02:26 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I never alleged it did Steve. I was simply replying to an observation.
Old Jun 30, 2005 | 07:41 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
:raises hand:
I have 2 of em.
1 is already .030 over and needs to go .040
1 is a virgin block thats Im doing a short fill on and stuffin in a 4inch strok crank. some 8.5:1 forged slugs and a huge turbo.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
