Bore Measuring
Old Sep 13, 2001 | 08:29 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Bore Measuring
i put a piston ring in my cylinder on the unworn ridge, the ring gap is 0.021" and under the ridge the ring gap is 0.023" is there some formula to figure out if i have to bore it or could i just hone the cylinder?
[This message has been edited by 86Z (edited September 13, 2001).]
Old Sep 13, 2001 | 09:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The circumference of a circle is pi times the diameter. Pi is about 3.14159265359. So if your ring gap is .002" different between those 2 points, then the circumfernce of the bore is about .002" greater; which means the bore is somewhat less than .001" bigger. IMO you should be able to hone it (to restore the original style of cross-hatch pattern, which is very important) and run it without boring it.
ICON Motorsports
Old Sep 13, 2001 | 10:36 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
thanx RB!!, also i was checking the rod bearings on the #5 cyl, the tabs that go in the grooves are flat on just one rod? something i should look for? the crank doesnt look scored or anything.
Old Sep 13, 2001 | 06:07 PM
ede's Avatar
ede
i like to check the bore for taper and out of round (with dial bore gauge or telescope gauges), which i doubt if your ring end gab method would allow.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulasOnly
Jul 23, 2018 08:47 AM
AUZ28
Oct 3, 2015 06:28 PM
hartsmike
Oct 2, 2015 07:11 AM
