Idle surging on startup
Old Jun 27, 2005 | 05:56 PM
Mr. Brett's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7 TPI
Engine is an L98 TPI with a ZZ4 cam. Other than that it's pretty much bone stock. Was running fine and then out of nowhere started surging at idle on startup. It normally idles at around 700-750, but now it's surging between 500-1200 on startup and almost stalls. It does this for about 30-45 seconds and then smoothes out. It does it every time I start the car and always smoothes out after about 30 seconds. Any ideas? MAF? Vacuum leak? Help!
Old Jun 30, 2005 | 09:56 AM
Mr. Brett's Avatar
Engine: 5.7 TPI
Anybody have any ideas?
Old Jun 30, 2005 | 05:31 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
look for vacume leaks then go from there, i had a surge at idle with my 2.8 block and it was due to vacume leaks.. i might just figure out a way to change all my vacume lines to metal so i dont have to worry about it again..
Brandon
tyeo098
Nov 30, 2015 06:27 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
