Engine running rough...Literally....
Old Jun 29, 2005 | 07:09 AM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Ok, I will try to desscribe as best as I can....
Monday on the way to work it was fine, ran strong as usual. Monday on the way home, it was really rough. Literally shook me to death. Didn't drive it Tuesday, drove this morning, and still shaking like a Mo Fo.
No odd noises, except at the moment of shake, the exhaust gets quiet. Almost sounds like a piston isn't firing. Similar to when I blew a head gasket, but no white steam out he tailpipe and no magically disappearing radiator fluid.
I thouhgt maybe transmission since I had the rebuilt a few months back, but even in Neutral it shakes the whole car. the shake gets real bad around 1100 rpm, I havn't gotten it past 2k since the problem started.
It has been 60k miles since the last tune-up, although I did put new plugs (Bosch Platinum+4) a year ago when I changed head gaskets. All fluids are fine.
I am thinking Tune-up (although last time I noticed a decrease in performance over time, not quick like this time)?? Fuel Injector?? Head Gasket??
Any advice appreciated.
Thanks.
Old Jun 29, 2005 | 09:09 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Start with the simple stuff. Cap, rotor, and possibly wires. Mine has a habit of vibrating the wires onto the exhaust manifolds, and burning thru. Ooops. Instant miss.
Could also possibly be a module, or pickup coil.
Old Jun 29, 2005 | 12:39 PM
scanman717's Avatar
Engine: LB9
More info... Was just out driving at lunch and it threw code 45 (Rich O2 sensor)... hmmm.. Probably means something isn't firing and pushing gas into the exhaust.....
Old Jun 30, 2005 | 02:34 PM
scanman717's Avatar
Engine: LB9
Ok, more interesting info... Drove it to work this morning, and everything is fine.. WTF???
Guess I will take this as a sign and do a tune-up.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
