What do you call these, quick help please!
Old Jun 29, 2005 | 06:48 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
I broke 2 of those little black rings that are on the valve stem, but then i tried installing a spring, and it seated just fine and is being held just fine with hte keepers, will it hurt for the #1 cylinder to not have them? Can i just get them at autozone?
Old Jun 29, 2005 | 07:14 PM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Were those little black rings made of rubber? If so I'd guess that they might be the valve stem oil seals? Otherwise I'm not sure what you're trying to describe.
Mark.
Old Jun 29, 2005 | 07:17 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
I dont know, they were hard.
Old Jun 29, 2005 | 07:24 PM
91Z28-350's Avatar
Valve stem seals. Get the umbrella seals from your parts store, made by Fel-Pro. I use the umbrella + o-ring (included in the Fel-Pro package). You can choose to not use the o-ring.
Old Jun 29, 2005 | 07:28 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Studied a haynes manual, thats what they were.
Old Jun 29, 2005 | 08:00 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
i use both umbrella and o-rings, double protection
Old Jul 9, 2005 | 04:26 AM
The_Beast's Avatar
Car: 91 rs
Engine: 5.7 350 :))
Transmission: 700 r4
Axle/Gears: 1996 - 3.42
Hey. Im going to have to replace my valve seals soon and I wanted a little info on some. I was thinking about getting a set of Crane Cams Hi-Performance Teflon Valve stem seals. Is there anything special i should know about going with these or any reasons why or why not to get them? Theres also comp cams and fel-pro i could go with.
F-body-fan
May 4, 2026 09:42 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
mackjar66
Sep 14, 2015 01:17 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
