Stumped
Old Sep 16, 2001 | 05:00 PM
Azarel's Avatar
Stumped
Hey guys,
I have a 1992 Camaro RS 305 tbi 5spd. When I crank it up the idle fluctuates or "hunts" if you will from 1k, then drops to 200, comes close to cutting off, then idles back up. This process goes away somewhat after I've driven it (the hunting is miniscule, but still there, both in open and closed loop).
So far, I have replaced the MAP sensor, IAC motor, the Coolant Temp sensor. I checked vaccuum and it seems to be around 20 when its kind of steady idle, but drops when the idle drops, etc. I've checked the PCV and it works like a charm.
My question is what to do next. Should i go about replacing the O2 sensor? or? I am stumped.
Thanks,
Azarel
1992 25th Anniversary Ed. Camaro RS
Old Sep 16, 2001 | 06:35 PM
CamaroRS1990Guy's Avatar
Car: 1990 Camaro RS
Engine: 305 soon to be 383
same thing happen to mine so i adjusted the idle speed it is located near the right side of the carb i had to kow out the pin off of it the it just uses a tork rench
Old Sep 17, 2001 | 12:27 PM
Azarel's Avatar
Update:
I've been working with a local GM guy and we've located a vaccuum leak behind the heater control panel. That seems to be the source of the problem. I'm going to order a new unit from GM and replace it and see if that stops the vaccuum leak and the bad idle altogether.
Az.
Old Sep 17, 2001 | 07:19 PM
Vader's Avatar
Another possible and fairly common cause is a worn throttle shaft or loose throttle plates.
Later,
Vader
Justice and Freedom will Prevail
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
