Steering column problem
Old Sep 18, 2001 | 12:32 AM
ADMZ24's Avatar
Car: 1991 Trans Am
ALright, a while back my bright and dim switch kinda broke. I thought no big deal, but now there is more to the problem. Tonight I hit my right signal, and a peice fell out and hit my leg. It looks like a bolt without a head. It has grease on it. First of all, what is this??? The column has a lot of play at the point where it goes through the dash. I can push down on the steering wheel and it bends about 4 or 5 inches. What am I gonna have to do....New column or can I get new parts?? If so, from where?? Need to figure this out....
1991 WS6 Trans Am
Medium Green Metallic
Beechwood interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
K&N Filter
Macewen white faced overlays with Xenon bulbs
Firehawk SZ50's
KYB GR-2 Struts
KYB Gas-a-Just Shocks
Pioneer DEH-630
Old Sep 18, 2001 | 07:31 AM
Hulk0202's Avatar
Im not sure, but check to see if your highbeams still come on. I have a 91Firebird, and I lost some type of linkage in the column that caused my his not to switch on. I never saw the piece, but thats what it would look like. I have some play in my tilt too. Been there ever since we got the car new.
Old Sep 18, 2001 | 08:54 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Sounds to me like your tilt support has come loose from the lower column. If you can move the steering wheel up and down at the point where it is supposed to tilt (without pulling the little lever......) Then you need to tear the column down, and tighten it up. This is about a 3 to 4 hour job, and requires a steering wheel puller, and a locking ring compressor. Other than that, just a selection of screwdrivers, and torx bits, and you should be good to go. It is not really difficult, just time consuming, and trying to figger out how the parts that fell out go back in can be fun too.
Good luck....
Old Sep 18, 2001 | 10:50 AM
ADMZ24's Avatar
Car: 1991 Trans Am
I also have the air bag in my car, the Haynes manual explains how to disarm it, but how do i take it off??? Just the bolts on the back and pull it out??
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
