fuel line replacement
Old Jul 6, 2005 | 09:28 PM
RJR99SS's Avatar
The fuel pump went out on my 89 305 tbi rs. The problem is all 4 fuel lines are badly rotted, and need replaced as well.
The fuel filter hasnt been changed in forever, because the nut was rounded off, and the line being so rusted. The line that goes from the fuel filter to the tank is rusted as well. Does that mean i need a new sending unit?
As for the lines, i'm wondering if i can just bend those up myself. What kind of flare do they use? do parts stores even stock line that size? I looked around the net and the pre-bent replacements are upwards of $100 per line, i'm not totally comfortable paying that much just for a single line.
Old Jul 6, 2005 | 11:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
If your pump is gone and everything else is toast, well, were it me I'd probably replace everything while I was down there.
Yes you can bend it yourself, not sure of the correct type of flair, but I've used a double when making my own. Why not try and find some salvageable ones in the boneyard?
Old Jul 6, 2005 | 11:06 PM
RJR99SS's Avatar
well this is ohio, the rust belt, so i highly doubt i'd find anything usable in the boneyard.
Old Jul 6, 2005 | 11:08 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Call a boneyard somewhere else (I've had stuff shipped from boneyards out of state before), or bug someone on ebay that's parting out a car, or even post in the -wanted- section. It might be work, but bending a full system line as your first try isn't exactly fun either.
Old Jul 6, 2005 | 11:10 PM
RJR99SS's Avatar
Well this isnt the first time i've bent line. It would be around my 60th time or so. I just dont know if what flare to use (without me ripping it apart first) and all that.
Old Jul 6, 2005 | 11:12 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
:shrug: What's the diff.? If you're gonna bend it you have to pull it apart. Mayby pull the one in the engine compartment as it's easiest to get to. Just don't do what sooo many turdgenners do and use compression fittings.
Old Jul 6, 2005 | 11:14 PM
RJR99SS's Avatar
Yeah, thats not even an option. One of my mechanics at work said to just replace it all with rubber fuel injection hose (no wonder i have to warrenty work for customers so much).
Old Jul 6, 2005 | 11:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by RJR99SS
... One of my mechanics at work said to just replace it all with rubber fuel injection hose...
I hope you took some of that hose and smacked him upside the head with it. Man, that would be one helluva reeadneck looking thirdgen... hose hanging and dragging down... -shudder-... smack that 'mechanic' once for me too.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
