do i have too much valve spring for hydraulic lifters?
Car: 91 formula
Engine: 355
I've got some pretty bad valve train ticking. I'm using the LT4 hot cam with springs with 135#@1.75 and 360#@1.20. I've already rechecked the lash(0 then 3/4 turn) and the lifters were out of a engine with 8k and no ticking. I'm wondering if anyone else has ran a spring this heavy with factory roller lifters without problems. I'm using comp pro magnum 1.6 full roller rockers also if that makes a difference.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That pressure is just right....don't see how that could be your problem. Might reajust them to 1/2 a turn from 0
Car: 91 formula
Engine: 355
Thanks for the replys. The injectors definetely make some noise but I didn't think they could be as loud as this is. Maybe I'll see if I can get it to run by spraying carb clean in it and unplug the injectors. If they're not it I guess the valve covers will come off again and I'll break out the stethescope. Good to know I don't need to change valve springs though.
Car: 91 Z28
Engine: 468 ci
Transmission: thm 350
If you're running the stock center bolt valve covers, you have to cut out the braces inside because the pro-mags hit. I had to do this with my wife's 89 TA.
Re: do i have too much valve spring for hydraulic lifters?
You must get the correct springs that go with that cam your using. Then they must have the correct installed height, to attain the proper seat pressure. IIRC, the "factory" rollers should not have more than 110 on the seat. I could be wrong though. Call GMPP, and get the info, if you do not have the cam card.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: do i have too much valve spring for hydraulic lifters?
One of the most popular springs folks use for 'hot' hydraulic rollers are the comp 987s, which are I think 125lbs..
- Joe
Car: 91 formula
Engine: 355
I decided to throw away the "claimer" (I know, I know, I had a new set left over from my oval track motors) valve springs I was using and ordered some crane 99846s. Wish I would have thought about this stuff more when the heads were getting the guides cut down, should have had the spring seats cut bigger also. the hot cam comes in a cardboard tube with no paperwork just like a stock replacement cam, so I figured I'd use what crane recommends for their cams that are similar to it.
Car: 1989 IROC-Z Convertible
Transmission: Art Carr 700-R4
Crane 99846 springs
I just got a set of these, too, as I'm adding a Crane Powermax to my 305 soon. One thing to consider is, however, that the numbers listed on Summit Racing's site aren't consistent with Crane's own numbers (on their site). To confuse things even more, the sheet that came with the springs gives the same numbers as Summit, so it all boils down to checking these things yourself, or having a machinist do it for you. Also, the Crane tech guy got a little flustered when I told him I was using these with the lower lift hyd. roller (.452/.429). I plan on using some offset locks to hopefully bring the pressure into the 110 to 120 range. If you're "fighting the clock" to get your project done, this is another thing to consider.
Re: Re: Re: do i have too much valve spring for hydraulic lifters?
Originally posted by anesthes
Yes your wrong.. 110lbs on the seat is not enough for a healthy hydraulic roller cam.
- Joe
- Joe
Car: 1989 Iroc-Z
Engine: 350ci SBC
I am running 175lbs on the seat and 400lbs over the nose. I am also running the Comp Cams R lifters. The stock ones would not let the motor rev past 5000rpm. Now it will rev to 7000rpm...
Hotrodboba400
Dec 10, 2019 07:07 PM
