camaro
Old Jul 7, 2005 | 09:06 PM
chevrunner21's Avatar
Car: 1992 trans am
Engine: 305 tpi
camaro
no it's not tuned port but it's 4 bbl but i thought all irocs were 305 h/o.
Old Jul 8, 2005 | 04:06 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Not all IROCs have the 305 ho. My 86 had TPI on it with the standard 305. If its a 4 bbl then it may have been modified by someone. If your the only owner then it may have a q-jet but I thought the last ones were put on in 85?
Old Jul 8, 2005 | 09:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Carbs were used through the 1987 model year. TPI started as an option in the 1985 year model.
The only "HO" models were carb'd 305's which were the VIN G L69 models, primarily in the 1983 - 1985 model years, with only a very few made in the 1986 model year. Those that have a 1986 HO generally know it without a doubt.
An IROC, Z28, etc., appearance package is no guarantee of a "high performance" engine.
Old Jul 8, 2005 | 11:03 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
check your RPO's they are on the inside passenger side of the center console, if not you have to run your vin which is on the windshield, inside the passenger side fender , trunk etc.
RPO List
B4Z IROC PACKAGE
1FP87 Camaro Z28 Sport Coupe, 8-cylinder
You can still have an LG4 and have an Iroc, just really smogged Iroc.
Old Jul 9, 2005 | 11:05 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
RPO List
B4Z IROC PACKAGE
In that rpo list, it shows only 2 available codes that start with 'G', I was wondering if that was a complete listing of the codes? I have an 88 and I am wondering if I have posi, I have 1 'G' code listed on my sticker, but I cant tell if it's a g80 or not. The other 'G' code says it's for z28 only, I have a mpfi 2.8 v6 (non z28 obviously). The sticker is damaged where the code listing is, so I can only see that it is a code that starts with a 'G'
Sorry, not trying to steal the thread.
Old Jul 9, 2005 | 11:15 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
im pretty sure all 88' sixers are open
Old Jul 9, 2005 | 12:51 PM
Car: 88 Camaro
Engine: 310 LG4
Open?
Old Jul 9, 2005 | 03:29 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
open differential, not posi only one wheel spins you could convert it for a couple hundred but with a 2.8 it would have to be for safety reasons.
Old Jul 9, 2005 | 03:50 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
There are a lot more 'g' codes: http://www.nastyz28.com/rpomenu.html
My '87 2.8, has 'GU6' = 3.42 rear axle ratio
Old Jul 9, 2005 | 05:15 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
My Iroc came with an LG4, 700r4, aluminum rear drums, and a 2.73 open differential ... It now has 355 and 3.73/eaton posi.. Just upgrade!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
