Diffrence between lg4 and l69 chip?
Old Jun 8, 2001 | 11:37 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I was wondering if I should order one for a l69 5 speed instead of the a lg4, after market of coruse, I put a 350 in place of the lg4 and I don't want to buy a costom chip, the car has a 5 spped if I can does anyone know the chip code? the car is a 86. thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jun 9, 2001 | 01:57 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Does your LG4 have a knock sensor? The L69 does, and if yours doesnt, you'll get a constant SES light as the computer looks for your knock sensor.
Aftermarket chips are junk, just save your money. Especially for carb cars, there really isnt much the computer does for them.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 9, 2001 | 07:14 AM
BLACK Z's Avatar
Car: 86 Z28
yes my car has a knock sensor, I changed it over to the 350 sensor and module.
Old Jun 9, 2001 | 08:11 AM
83_TA's Avatar
Save your money.. Buy a new didtributor & good ignition system.. I bought an MSD 6A system & distributor and it made a world of difference..
I was going to buy a chip, but was told that it wouldn't make that much of a difference..
Old Jun 9, 2001 | 12:10 PM
Golden80's Avatar
You buy a new non-comp distributor then you have to buy a non-comp controlled carb also. And vice versa.
Matt
Old Sep 19, 2001 | 08:23 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Sep 20, 2001 | 02:24 PM
Damon's Avatar
The L-69 has a better spark advance curve but that's about it, aside from knock sensor issues. If you really want to get a chip then just get a standard "stage 1" chip for your year of LG-4. It will have a more agressive timing curve but will otherwise work with everything else that came stock on your LG-4. Not stirctly necessary, IMHO, though. Bump up the timing 4-6* over the stock setting and you get basically the same results for $0.
[This message has been edited by Damon (edited September 20, 2001).]
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
