crazy oil pressure gauge
Old Jul 13, 2005 | 01:54 AM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
When the car is idling, the oil pressure reads under 30, but as soon as I touch the gas, the needle shoots up and goes past 60, like it's maxed out. So whenever I'm driving around the gauge is pegged past 60 - do you think the sender is just bad? Any help is appreciated. Thanks!
Old Jul 13, 2005 | 07:47 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: crazy oil pressure gauge
When I broke in the cam on my 388 the oil psi pegged at 40, asked the builder about it, and he said to change the oil filter, which I had to do anyway, problem solved.
Problably due to a weak filter bypass valve spring, not good because unfiltered oil is getting into the engine.
Old Jul 13, 2005 | 09:49 AM
Car: 1989 Trans Am
Engine: l98
well I've changed the oil filter several times since I've had the car with no effect
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
