Lost nut in engine
Old Sep 22, 2001 | 04:12 AM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
Lost nut in engine
hey, i accedently droped a nut into the valley of my engine(with the push rods and rollers) and it seems to have fallen down one of the three holes near the firewall. it sounded like it fell down quite far so my question is, where is it? im guessing its in the oil pan, and it doesnt look like its in the distributor hole. i really dont want to pull my engine out because i dont have a hoist, or the money to rent one. is it at ALL possible to remove the oil pan without pulling the engine? if removeing the engine is my only choice, how much do engine hoist's cost to rent? or buy even?
Old Sep 22, 2001 | 08:04 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
You should be able to rent an engine hoist for about $25 U.S. for the day. You won't have to pull the engine all the way, maybe a foot to get clearance under the pan. Good thing you noticed before you fired up the motor. I dropped a screwdriver tip in my #1 cylinder and didn't know it until I fired up the car
I have heard that large objects like a nut will just sit in the bottom of the pan and not go anywhere, but I cannot confirm this.
Good luck and If you can't afford a hoist, find a large tree with a stout branch, we used to do that at our house in Baltimore.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Sep 23, 2001 | 03:17 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Get a magnet on a flexible wand and see if you can't retrieve it from the top, down along the distributer, ect...
Another place to try is through the oil drain hole....
You might get lucky and it's a tool that won't go to waste.
Old Sep 23, 2001 | 08:46 AM
ede's Avatar
ede
well i believe i'd worry about it, but there is a good chance it fell straight thru and is laying in the bottom of the oil pan. there isn't really a lot of places it could get stuck. i'd try with a magnet like you've been told and if you don't find it i'd turn the engine over by hand to see if anything hits or binds up.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Infested
May 22, 2018 11:56 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
djmarch
Aug 19, 2015 12:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
