Underdrive Pulleys
Old Jul 15, 2005 | 10:16 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Underdrive Pulleys
Hey All,
My friend recently introduced me to the world of underdrive pulleys as he has had them installed in his focus. Well in the end I noticed a decent difference in how his car pulled around over the stock pulleys.
I did some searching around and noticed that Thunder Racing sells them for our cars. Is this a good mod to do to gain a bit more power out of the car?
Old Jul 15, 2005 | 11:34 PM
91rs305tbi's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 700r4??
i wanted to install them on my car then i heard they dont do much to our cars, but hey i might have been told wrong...my friend did them on his stang and there was a difference.
Old Jul 15, 2005 | 11:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You lose something to gain a bit of power, ie less current from the alt, or less power steering, less water flow from the water pump, etc. All to gain a very slight amount of power.
My personal opinion is the money is better spent elsewhere...
Old Jul 16, 2005 | 12:25 AM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
I like mine and got them for pretty cheap from another member.
Every little bit counts plus its an easy mod. I have no charging problems either.
Old Jul 19, 2005 | 08:49 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
https://www.thirdgen.org/techbb2/sho...hreadid=310616
Power and Amp series, won't affect your charging system.
Old Jul 20, 2005 | 12:12 AM
moneyman380's Avatar
Car: 1991 Z28
I wish i didnt even buy mine, I have a noticeable difference in power steering and my alternator cannot even charge my battery at idle. Dont waste the money. At least dont buy the ones from MOTORVATION through Summit.
Old Jul 20, 2005 | 12:16 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Is the powersteering harder to turn? If it is, without any detrimental effects. I might install a bigger pulley to increase steering effort.
Old Jul 20, 2005 | 12:28 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
I kinda like the fact its harder to turn on mine, the quick ratio, 13" wheel and underdrive pulleys give it a pretty nice feel..
if your at like 1000rpm or under and it downshifts you feel a change though, thats a little weird going around turns :P
Old Jul 20, 2005 | 10:09 AM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
I put a set on my dirt car, it kept throwing belts off at about 6800rpm's. I don't notice any power difference (not running alternator or ac pump) but steering is fine and cooling is fine. If cooling became a problem a more aggressive fan may help, there is a ford truck fan out there that a local race engine shop uses, they say it is good for a 20 degree drop by itself.
Old Jul 25, 2005 | 01:51 AM
Night rider327's Avatar
Car: 1988 Camaro
When I built my 355 for my 88 camaro I done before/after testing. Sat down and figured out all the pulley sizes I wanted/needed. Bought them (no kit deal)
I ran stock pulleys. 4 runs, avg. together.
Swapped to new underdrive pulleys. 4 runs, avg. together..
I lowered my ET by a solid .2 second.
IMO worth every bit of the money.
Now I'm running some pretty high % under drive though.
I have a CS-130 105 amp alt., mildon high flow water pump, ford taurus 2 speed elec fan, and 31" x 19" alum rad.
At a 700 rpm idle with fan on low I have 12.3 volts, but at 900 rpm I have 13.1 volts.. Cruzing down the road at 2700-3000 rpm I'm at 14.8 volts
Water temp runs on avg. in summer 193* on a long 40+ mile drive.
Mine is a V belt setup, and I mixed and matched my after market pulleys.
All polished alum.
Crank pully is a 5.5" 2 groove march pulley,
water pump is a 6.6" single groove summit pulley
ALT. is a 2.812" single groove summit pulley
Power steering is a 5.75" single groove summit pulley
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
