Non thirdgen, 88 chev full size truck driveshaft
Old Sep 23, 2001 | 12:39 PM
Keith5's Avatar
Car: C1500
My Dad has an 88 chevrolet silverado 1500 and he has a question about his driveshaft. It is an aluminum driveshaft with a fiberglass cover over it. What is the fiberglass part for? His is tearing and he doesn't know whether to tear it on off or to tape it up.
1989 Pontiac Firebird Formula LO3/700R4
-180 degree stat, Hooker Cat-Back, Wonder Bar
http://www.geocities.com/krt80/
Old Sep 23, 2001 | 02:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If you tape it up it could cause a vibration.
If the outer skin is coming off, I would go get a new one. Even though there is aluminum underneath the FG...as the pieces come off it will lose balance.
Call a local driveline shop, they can fix/replace just about any driveline.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 23, 2001 | 09:40 PM
Keith5's Avatar
Car: C1500
But what is that skin for?
Old Sep 23, 2001 | 09:58 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Don't know, could be some sort of sound deadener, to keep high RPM "drone" out.
Could be a little strength support.
Anybody else got an idea??
All I know is that if you alter the weight of the driveline by removing or adding weight, it will vibrate.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited September 23, 2001).]
Old Sep 23, 2001 | 10:11 PM
Vader's Avatar
I'll bet Red Devil knows...
Later,
Vader
Justice and Freedom will Prevail
Old Sep 24, 2001 | 01:38 AM
85 Berl's Avatar
I'll bet it's just another useless feature stuck on a perfectly good truck that has no function but to break later in life.
Jeff
'85 Berlinetta, Special Beater Edition
Mods include a 4bolt 350 with 280*, .460 lift cam, Vortec heads, Comp Cams roller tip rockers, Edelbrock TES headers, no other exhaust . Also, rusted parts on all 4 corners, and crumpled fenders, thanks to the previous owner.
Terrell351
Jun 13, 2021 01:13 PM
Linson
Aug 21, 2015 02:12 PM
355tpipickup
Aug 13, 2015 07:35 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
