Couple cam swap questions....
Old Jul 18, 2005 | 01:09 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
Hey guys just in the middle of my cam swap and had a few ?? for ya.....
1. when going back on with the intake manifold.....do you use black RTV or is there a special sealant/gasket maker I should get.
2. when going back on with the balancer can it be slid on with a block of wood and hammer.....avoiding the outside of the HB of course...mabe put the pully on first then tap it on???
3. one of my crane gold RR came loose about 10K miles ago and started tapping....I pulled the valve cover off and fixed it....when I removed the RR yesterday and took a close look at it I noticed it had some nicks on the main body...looks like the stud bolt rubed it a bit....there are a couple other nicks where the push rod contacts it too...is this somthing to worry about?
...thanks for any input!!!
350Z
Old Jul 18, 2005 | 01:13 PM
ede's Avatar
ede
black rtv is fine, i use the ultracopper. i'd buy or rent an intaller tool for the dampner. i'd replace the rocker.
Old Jul 18, 2005 | 02:25 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I like ede use the ultra copper RTV on the intake, but the black will work.
I personally would not tap on the balance. In no way shape or form would I do that. Some do and have no problems, but I prefer to keep the added stress from tapping the front bearing around like that pushing on the crank...
I ended up using a longer grade 8 bold of the same thread pitch and washers to push my balancer on. Longer so that when you start you have more threads in the crank snout than just 2-3. The further you go the more washers you add.
Replace the rocker...
Old Jul 18, 2005 | 03:33 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
...cool...thanks for the info...here is another one I just thought of....I've heard that some cam gears will not work with the distributor gear...running an comp cams xfi cam....would they really have a gear that won't work with the dist. gear?
Thanks Again....350Z
Old Jul 18, 2005 | 09:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Don't hammer on the balancer. You can make a balancer installer using 1 SBC cylinder head stud with a nut and some washers. the fine thread on one end of the cylinder head stud is just right to thread into your SBC crank.
If you're friendly with a performance shop they may have one laying around.
If the body of a roller rocker is just nicked you can smooth out the nick wth a die grinder. If the trunion , bearing tip or pushrod seat is damaged, get another one.
Old Jul 18, 2005 | 11:01 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
[IMG]C:\DocumentsandSettings\Owner\Desktop\rr2.JPG[/IMG]
here is a pic of the rocker....
Old Jul 18, 2005 | 11:03 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
crap...didn't wurk...
Frozer!!!
Jan 19, 2024 04:55 PM
Cameeeero
Sep 18, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
