A/C Delete 91' 305 TBI SERPENTINE SET UP
Old Jul 20, 2005 | 09:14 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I have a 305 tbi serpentine set up (electric fan)
Im going to remove the A/C/ and needed help on doing so, also is this the correct ac delete pulley?
I will post pics of my engine and A/C for willing people to help me out .
Thanks!
Old Jul 20, 2005 | 09:36 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Heres my engine bay, please let me know what i'll have to remove
Old Jul 20, 2005 | 09:37 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
yes my engine is filthy!!!!! and the bay is ugly but I will revive it soon!
Old Jul 20, 2005 | 09:42 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
and my manifold is leaking oil...
Old Jul 20, 2005 | 10:24 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
will I need this as well?
Old Jul 20, 2005 | 11:12 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You'll only need the smog delete, if you're taking of the smog pump.
Old Jul 20, 2005 | 02:17 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Alright is that all? just those 2?
Old Jul 20, 2005 | 03:01 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
You know you live in California right, where a smog pump is required??
Old Jul 20, 2005 | 04:09 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I got friends who work at smog stations.. no worries mah son.
Old Jul 20, 2005 | 04:31 PM
cali92RS's Avatar
Car: White KSwisses
First of all, i aint your son. Dont get it twisted.
Second, if you want to f_ck up your car go ahead.
Old Jul 20, 2005 | 05:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Can anyone see the pictures? I can't but it may be my PC.
Old Jul 20, 2005 | 07:03 PM
Abubaca's Avatar
Hey it's not his fault you don't "know someone".
Old Jul 20, 2005 | 07:44 PM
cali92RS's Avatar
Car: White KSwisses
Thats not why I was annoyed...son
Old Jul 20, 2005 | 07:47 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
What is that??? and what does it do?
Old Jul 20, 2005 | 08:41 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Smog pump diverter valve.....
Old Jul 20, 2005 | 09:19 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
No wonder there is a massive cloud hovering over cali. All you hot dogs seem to need a few tenths more than clean O2.
Two questions:
Why do you want to ditch the AC when you live in cali?
Why not fix your leaks with the $ instead?
Not flamin' It is just that the gains from ditching that stuff are really pointless on a street car. Not to mention that "I know a guy stuff" can get you both in deep $$$hit when caught.
Old Jul 20, 2005 | 09:33 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
i dont know about ac delete. i just know that they make a pulley to keep ur setup the same. as far as the smog pump. its directly below ur ac compressor. and that box u asked about is part of the same system. u can literally unbolt the pump, pull out the plumbing; the only thing is u will need to get sum plugs for ur manifolds (local hardware store). and ur set... i dont wanna get into the bicker over smog... but it was easy. oh and u'll need a 96.8" long 6 rib belt. this tech article is where i got my info when i did it. https://www.thirdgen.org/newdesign/t...rpentine.shtml
do a to find out exactly what size plugs to use in ur manifolds. i got all my info from these forums...
Old Jul 20, 2005 | 10:19 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Ok im going to remove the AC and leave the smog pump there? is that possible too? I want to keep the hippies happy.
Old Jul 20, 2005 | 10:31 PM
Car: 89 camaro rs
Engine: 305 tbi
thats great haha. but y? if u have friends... and u wanna do sumthin to ***YOUR*** car... id say do it... thats just me... i wont say do it with intentions of pissing anyone off tho...
Old Jul 20, 2005 | 10:35 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Ive never even heard of a smog pump before!!??? what the hell is that?? it sounds disgusting like some little smog factory that makes smog... im going to remove it.
Old Jul 20, 2005 | 10:37 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
thanks for everyone's positive feedback!!
Old Jul 20, 2005 | 10:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If your deleting the A/C, have the system discharged, remove all the A/C related stuff, put the A/C delete pully in place, and your done...
Old Jul 20, 2005 | 10:44 PM
Car: 88 Camaro SC
Engine: SFI'd 350
No... Its basically an airpump. The ECM, which controls the air diverter valve, diverts air either to the manifolds, cat, or the ambient air. The air to teh manifolds reduces emmisions when the engine is cold, the air to the cat helps reduce emmisions when the engine is warm and at low loads. High loads, higher rpms, the air is exhausted back out to prevent damage to the cat.
Old Jul 21, 2005 | 12:29 PM
Car: 89 camaro rs
Engine: 305 tbi
i forgot to mention the air tube to the cat. i dont know the correct way (if there is one) of capping this or blocking it off. but i cut it off close to the cat, then heated and crimped it. however i did this with it off of the car. good luck and have fun.
Old Jul 21, 2005 | 10:24 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
thanks!!!
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
MENINBLK
Aug 5, 2015 11:58 PM
