MAF question?
Old Jul 20, 2005 | 02:58 PM
#32pontiac's Avatar
Car: 1988 Pontiac GTA
Engine: 350 TPI, With roller lifters
Transmission: 4 speed 700r4
MAF question?
Hello,I have a L98 350, and it would not start this morning again. So I unplugged the MAF sensor, and plugged it in again. The car started up, and ran fine. What do you think the problem is.
Old Jul 20, 2005 | 03:00 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Dice odds say MAF relay likely.
Old Jul 20, 2005 | 05:39 PM
Vader's Avatar
Yup. The coin flip also indicates the likelihood of a problem with the MAF relays or connections.
Old Jul 20, 2005 | 07:11 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Don't forget it could just be a coincidence and the MAF connection had nothing at all to do with it.
Old Jul 21, 2005 | 10:17 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Could be it was loose or had a bad connection due to some minor corrosion on the terminals. Could be you could use some dielectric grease in the weather pac connector to try and help it out some...
Old Jul 21, 2005 | 10:28 AM
#32pontiac's Avatar
The car this morning will not start at all, even when I try my little tricks. You Guys have to understand that this car is the biggest piece of crap that I have ever owned in my life, and that is a bold statment because I have even owned a dodge shawdo.
The bottom line is that everything is new on this car, I have replaced the MAF relay before and, it just seems to never stop. I am at my end with this car. Thanks for all your help.
Old Jul 21, 2005 | 11:50 AM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
AFAIK there are two.
Old Jul 21, 2005 | 11:52 AM
#32pontiac's Avatar
Where is the second one ? I have replaced the one on the fire wall on the driver side.
Old Jul 21, 2005 | 12:15 PM
#32pontiac's Avatar
I have a chevy camaro service manual, and it shows only one sensor MAF power relay and a MAF burn off relay, if those are the two you are talking about then I have replaced both. If not then where is the other one
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
