reinstalling back the alternator
Old Jul 20, 2005 | 09:53 PM
buntnsteal10's Avatar
Car: 1987 Chevy Camaro IROC-Z
Engine: 350 L98
Hello everyone, my project is almost done that i need one more thing is that how the heck do i install my alternator back? i took out the smog pump and i mounted the alternator back but there is this black wire that connects to the negative terminal on the battery and i don't know where to put it on the alternator. Do you guys have any idea where that wire goes??
BTWBTW, does anyone have close up of the area where the alternator is supposed to be in a 87 iroc?
thanks
Old Jul 20, 2005 | 10:20 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There isn't a wire running from the alternator to the negative post on the battery... dunno how the v-belts are setup, but that should have a CS-120 style alternator on it still, which would mean it would have a weatherpack connector that plugs in (probably 3 wires), and the output wire (ring terminal). The output wire will either go to the positive battery terminal, or, more likely on that year, a positive battery junction. Someone with a similar car will have to give more specifics if needed.
Old Jul 20, 2005 | 11:22 PM
Engine: 350 L98
Yeah its a V-belt setup, the 2 connectors are fine with the alternator but i don't know where the negative battery cable should be connected to. i am having trouble with the negative cable that connects to the positive terminal on the battery
Old Jul 20, 2005 | 11:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think yuo're confusing some of us.
Negative terminal does not connect to positive on the battery.
Positive on the battery goes to the starter
Negative on the battery goes to the engine block...on my Serp setup (89) it goes to the Alternator bracket, IIRC.
Old Jul 20, 2005 | 11:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Oh, and welcome to thirdgen.org!
Old Jul 21, 2005 | 12:01 AM
Engine: 350 L98
Oh i am sorry yeah so the negative cable that connects to my negative terminal of the battery just connects to the bracket on the alternator? i have a bracket thats on the bottom of the alternator that used to connect to the smog pump so i just put that on the bracket and thats it?
BTW: Thanks this is a good website, i am also on iroczone.com
Old Jul 21, 2005 | 12:05 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yep, that's all you need to do
Old Jul 21, 2005 | 12:20 AM
Engine: 350 L98
thats it? ok thanks. I thought the negative have to connect somewhere in the alternator. it kinda works as a ground
its been awhile when i took an electronics class
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
backtothe80s
Sep 5, 2015 12:39 AM
Hello, Michael
Aug 20, 2015 03:19 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
