installed a new manifold, now it wont start
Old Sep 26, 2001 | 12:12 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
i just got done installing a new fuel pump, a new manifold and changed the oil, drained the coolant. i put everything back together and its looking good, then i go to start it last night and the battery died. i juiced the battery up last night, then i go to start it this morning and nothing. i remember to put gas in the carb since it all was drained when i removed it, and i put a little down the primaries. i go to start it and it almost starts, but gas emits from the primaries and smoke comes out of the carb. i go to start it again and i happens again, but the smoke gets less and less each time. did i flood it? did i pour gas down the wrong part? is this normal? any help would be greatly appreciated, thanks
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
Old Sep 26, 2001 | 12:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
As is always the cause of this, the distributor is not lined up correctly.
ICON Motorsports
[This message has been edited by RB83L69 (edited September 26, 2001).]
Old Sep 26, 2001 | 12:35 PM
Engine: LB9
Axle/Gears: 3:43
how would i go about lining the distributor back up correctly? would i have to back it out again? the stupid thing was a PITA.
Old Sep 26, 2001 | 01:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. You will have to take it back out and line the oil pump drive shaft up correctly, and then line up the distributor shaft correctly (keeping in mind that it rotates about 30° as it drops in), and drop it back in correctly. Piece of cake, about 5 minutes work.
ICON Motorsports
Old Sep 26, 2001 | 03:37 PM
Engine: LB9
Axle/Gears: 3:43
ive got the distributor out now but i dont know how to tell if the oil pump drive shaft is set correctly, and if the distributor shaft is set up correctly. last time i put the distributor in the manifold, then the oil pump drive shaft sat on something in the engine until i turned it then it fell into place, and i bolted everything back on. appearantly that was wrong, can anyone shed some light on this?
Old Sep 26, 2001 | 09:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What part of Northern Ca. are you in?
Anyway, best to get #1 at TDC, install the distributor so that the rotor is just shy of the #1plug wire on the cap (when the distributor is seated). As RB says, make sure the distributor engages the oil pump drive. You may have to reach down with a long, narrow screwdriver to rotate the pump drive slot. You'll have to "estimate" where the distributor drive will be, once it spins down on the cam gear.
Old Sep 26, 2001 | 11:44 PM
Engine: LB9
Axle/Gears: 3:43
8mike9, i live in stockton, for some reason i have the feeling we've already met. thanks for the advice, i just spent all day and night with my dad trying to figure it out. first we got what we thought was the correct position, then i started to crank it over and over and it just wouldnt catch. the battery then died. we then tried it all over again, and after a while we thought we had it again, the rotor pointed at wire number one on the cap, the timing mark was at zero, and the piston was up at the of cylinder one. i cranked it over and over and the carb kept spitting who knows what out. i quit for the night tonight, i have no clue what to do. should i keep with it or tow it to a shop? thanks
Old Sep 27, 2001 | 12:35 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Sounds like you may have set the distributor in at #1 TDC, but it should be on the COMPRESSION STROKE.
If not, you have symtoms like you're experiencing. While you turn the crank by hand, have someone stick the tip of thier finger in #1 sparkplug hole, and as soon as air starts to blow out while you turn, align your mark with "0" and set the rotor tip to align with the #1 terminal on your cap. It still sounds like a timing problem to me.
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling H.V. oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle Air Cleaner w/K&N Filter , Rhino Clutch, Crane 2040 Compu-cam, LS1 valve springs, porting, PST front end kit with new springs, and runs awesome!! Now for paint, interior, etc...etc.....Future Mods: Get rid of the 100 or so interior rattles.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
transaero
Aug 31, 2015 01:14 AM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
