Should I use synthetic oil?
Car: 1989 Firebird Formula
Engine: 305 TPI (Bone Stock)
Transmission: 700R4 (w/ mystery shiftkit)
I've heard this asked a bunch of times, and I've heard that cars with higher mileage are at risk, so i figured I'd get some opinions seeing as tomorrow is my FIRST oil change on my 'bird.
Ok, my car now has 62,000miles on it, no leaks or smoke... Does it sound like a good idea to run synthetic oil in this beast? TIA
Car: 89 camaro rs
Engine: 305 tbi
i was always told that synthetic is made to keep new engines new basically. and that with higher (75,000-ish) miles its not worth the extra dollars. then again you, hypothetically, wouldnt have to change it as often. i use high mileage oil with some lucas additive. but i go all out because i was losing pressure.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Originally posted by ede
any engine any time is a good time to run synthetic
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Unless it leaks like a chevy
then it gets too spendy!!
The only way I'd ever use synthetic in any engine is with the stipulation it does'nt leak!! Other than that, well worth the money for the extra protection.
then it gets too spendy!!The only way I'd ever use synthetic in any engine is with the stipulation it does'nt leak!! Other than that, well worth the money for the extra protection.
Transmission: 4L80E/4L80E
I switched mine over at 123k miles. The valve stem seals were hardened and cracked, so it used a quart every 600 miles. Changing the valve seals reduced that to about a quart every 2000 miles. But, it didn't leak.
"Synthetic" is too generic a term any more. Due to a court ruling, there are some products out there with "synthetic" on the label that are no better than the typical petroleum-based lube. With those, the only benefits are realized by those marketing them, new or old engine.
If you could be more specific about the brand/type you intend to use, a better answer can be given.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
heinz wouldn't the fake synthetics still be better then plain dino ****?
granted might not have the refinement of a true synthetic man made base stock but using the dino **** and refining it even more then the plain jane stuff would still be better correct?
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
Ive been using royal purple for about a year and im pretty impressed with it, noticed a little difference in power when i switched to it, runs a little cooler too.
Car: 1989 Trans Am
Engine: 355 HSR
Originally posted by Rabbitt
I currently use Castrol GTX.. i plan on switching over to Castrol Synthetic... good idea? bad?
Car: 89 Firebird
Engine: 355
Transmission: 700
I use Delo 400. 140,000 miles on the wifes van and it is still shiny in the valve cover.
BTW, don't use synthetic oil thinking you can leave it in longer. It is still an internal combustion engine and the filter is only good for about 1500 to 2000 miles, after that it is being bypassed for the most part.
I've been doing 1 year/25k mile oil changes with filter changes at half that interval with AMSOIL for 22 years. I have six vehicles currently, none with fewer than 145k miles on them. I haven't worn out an engine yet.
I will agree with you, though, if you're using one of the faux synthetics. I've never heard of Delo 400, what is it?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Originally posted by Chris89GTA
It sure ain't gonna hurt. Probably keep wear down on your parts for longer than the convential will.
I would recomend staying with them instead
Car: 89 Firebird
Engine: 355
Transmission: 700
Delo is really made for diesel engines but I asked a guy from Jasper Engines about it and he said that since it is made to handle the torcher of a diesel it will handle anything I do with an engine.
Today was over 100 deg, 30 min drive and oil pressure was at 65psi at idle.
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
Originally posted by IHI
Unless it leaks like a Harley
then it gets too spendy!!Junior Member
Originally posted by five7kid
Sometimes yes, sometimes no.
Delo is a big rig oil and also used alot by motorcycles that have wet clutches, though from what I've heard, not the preferred brand.
skinny z
Oct 5, 2015 06:23 PM
