what causes this and how do i clean it?
Old Jul 26, 2005 | 06:59 PM
Scheister's Avatar
Car: 85 IROC
im getting ready to put my intake manifold back on but i cant seem to get it completely clean. im posting pics below that will show what im having trouble cleaning. also what would cause those areas to get like that? and how do i get it clean? ive tried a razor blade and greese lightning, but neither worked.
thanx
Old Jul 26, 2005 | 07:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It looks like someone has used RTV to seal the coolant ports. Gasket remover and a little effort will get it off.
Old Jul 26, 2005 | 07:31 PM
Scheister's Avatar
Car: 85 IROC
ok thanks, ill try that tomorrow
Old Jul 27, 2005 | 11:53 AM
Scheister's Avatar
Car: 85 IROC
well i used loctite chisel gasket remover, scraper lots of scrubbing and its not coming off. any other ideas?
Old Jul 27, 2005 | 01:26 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Is the aluminum pitted where it's black?
Old Jul 27, 2005 | 01:33 PM
Scheister's Avatar
Car: 85 IROC
no its not pitted. no matter how much i scrape at it with a razor blade it dowsnt come off. i soaked it with the gasket remover all last night and today and it wont come off.
Old Jul 27, 2005 | 01:39 PM
ede's Avatar
ede
i use either a cup brush or scotch brite disk and a die grinder
Old Jul 27, 2005 | 01:43 PM
406TPI's Avatar
Car: 1985 IROC-Z
Get yourself a nice aggressive single cut flat file and run it over the machined surface until clean.
Old Jul 27, 2005 | 01:44 PM
Scheister's Avatar
Car: 85 IROC
i tried a demel with a buffing wheel and that didnt do anything either. i also tried the scotch bright pad and it didnt do anything.
Old Jul 27, 2005 | 02:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as you can get the surface flat so it will seal, I wouldn't worry about it too much.
Old Jul 27, 2005 | 04:06 PM
Scheister's Avatar
Car: 85 IROC
well i got a suggestion from another board on how to get if off and it worked... but it only took off what wasnt pitting. if i use lots of RTV will it be fine?
Old Jul 27, 2005 | 04:29 PM
91Z28-350's Avatar
what was the suggestion?
Old Jul 27, 2005 | 04:32 PM
Scheister's Avatar
Car: 85 IROC
using a plastic roloc, i think thats what its called, wheel on the end of a drill. it polished it up real quick and cleaned up what wasnt pitting.
Old Jul 27, 2005 | 04:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Wire wheel on the end of a drill. Works like a damn, and you'll find many other uses for it too.
Old Jul 27, 2005 | 04:59 PM
91Z28-350's Avatar
FWIW, that was ede's suggestion as well.
Old Jul 27, 2005 | 05:24 PM
Scheister's Avatar
Car: 85 IROC
wow, i guess i missed that one... sorry, i must have read right over it
Old Jul 27, 2005 | 11:41 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
I know BMW has a product there techs use to remove silicone. If you go to there parts dept. they should be able to get you some.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
