roller cam vs. big flat tappet cam
Old Jul 27, 2005 | 02:01 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Well I got my engine from the shop the other day. Found out that they lost my cam, lifters, retainers, lifter baffle, timing set up, etc. More than likely, I will be the one paying for it. The engine is an oem roller motor. Question is: should I go with a smaller hydraulic roller or a large hydraulic flat tappet? Which one will give more HP? Engine is for street use, needs vacuum. Money is a factor.
Old Jul 27, 2005 | 02:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Roller will give more power, but flat is much cheaper.
Old Jul 27, 2005 | 02:30 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
thats kinda what i was afraid of.
Old Jul 27, 2005 | 05:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The good news is you might be able to find used factory roller parts. With a flat tappet cam you'd be stuck buying new lifters.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
italiano67
Aug 31, 2015 06:04 PM
anesthes
Aug 8, 2015 09:37 PM
