Cooling Question
Cooling Question
Hi guys, I have a question, Im having problems with the engine running hot, its never boiling over, but the needle always indicates it over 220, I have a 1991 RS with a 305 TBI. I have changed the radiator, thermostat, radiator cap and some hoses and the water pump was changed yesterday. I am still running hot, im almost about to give up, anyone have suggestions or know any good Chevy mechanics in the fairfax virginia area, I just 400 bux for nothing at this one shop and am running low on patience with the car, thnx!! :confused
welcome to thirdgen.org, see if the radiator has leaves and stuff blocking it between the ac condenser and the radiator ,make sure the air dam is intact and directing air up into the radiator. you ought to check for leaks with a preaasue tester and if all that fails to solve your problem try having the radiator boiled out and flow tested.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Could your gauge be giving you a wrong reading?
383 86 Camaro Z28 ---1/4 mile e.t>12.89@108.8mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
thats a good suggestion, I just went out and spent 18 on the sensor, im gonna install it mon, ill let you guys know what happens, if this fails, im afraid I will have to put her down and get a new pup
Car: 1989 IROC-1
Any mods to the car?
What about the air dam under the car? If that is gone then the car will heat up.
Is the car hot always, or just when you are at a stop light?
the car has no mods, it runs hot all the time, I hear the fan kick in, so its not the fan. The mechanic said there was something he had to pull out of a hose, im lost on what it could be, Im gonna see him mon to find a solution
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Check to make sure the air dam is still inplace and thathere is no air in the system. My rommate had trouble and chenged everylast cooling piece on his 95TA only to discover that it was a blown head gasket. These problems are tough to figure out sometimes.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
2.8 MPFI, no mods
