Car idles funny, when cold
Old Oct 1, 2001 | 08:04 PM
91chevyZ's Avatar
I Have A 91 Camaro Z-28 with a 305 TPI and when I first start it up, it idles
with a lope(miss). After about 15 min of driving(engine warms up) it smooths out, every once in awhile it will have a little spurt of this problem, when its warm to, but not often. A regular tune up has been done spark plugs and wires, cap and rotor, air filters, and pcv valve. The car has 62,700 org miles, a compression test was also done
and was ok. Any suggestion
Old Oct 2, 2001 | 11:41 AM
formula87-350's Avatar
1. Temperature sensor might be bad. ECM thinks it's warm when it's actually cold.
2. Fuel pressure might me not high enough.
Old Oct 2, 2001 | 12:04 PM
IROCZ89's Avatar
Did you time it after the tune up?
Phil
Old Sep 13, 2009 | 11:46 AM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Re: Car idles funny, when cold
My 88 S/c does the same thing, have been told to check the E.G.R. Valve. Might try that.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
