How to fix a lean fuel mixture on mpfi???????
Old Sep 29, 2001 | 10:30 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I have a 2.8 with a automatic, the car has no power when accelerating which would account for the lean fuel mixture.Would this also cause my car to rev back and fourth just before my trans shifts into the next gear? Is there any way to fix these problems without having to take it to a mechanic.I've tried three guys in town and they want 1500 and up
Old Sep 29, 2001 | 10:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Start with the simple stuff...
Figure out what would keep gasoline from getting form the tank to the injectors. Changed the fuel filter lately?
ICON Motorsports
Old Sep 30, 2001 | 12:51 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Whats the fuel pressure?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Sep 30, 2001 | 10:29 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by branz28:
</font>
The fuel pressure is the amount of hydraulic force imparted by the fuel pump on the closed system, above standing atmospheric pressure, which is presumed at 14.7 pounds per square inch absolute, or 1 Bar, often expressed in PSI (Pounds per Square Inch), but more correctly expressed in PSIG (Pounds per Square Inch, Gauge) which accounts for the differential of measured pressure which is not absolute, but compared to the presumed standing atmospheric pressure.
That's the fuel pressure.
Later,
Vader
Justice and Freedom will Prevail
Adobe Acrobat Reader
Old Sep 30, 2001 | 10:38 AM
Vader's Avatar
Branz,
Yes, I can be a dìnk sometimes....
Later,
Vader
[This message has been edited by Vader (edited September 30, 2001).]
Old Sep 30, 2001 | 01:54 PM
Car: 85 Camaro SC
Engine: V6
I checked the fuel pressure at the shrader valve on the fuel rail.It was at 37 PSI when the engine was running and in P.BTW I need to get one of my rockers adjusted cause it nocks really bad,also could the knock sensor be retarding the timming soo much that it would cause a lean mix.
[This message has been edited by 85SportCoupeto89RS (edited September 30, 2001).]
Old Oct 1, 2001 | 06:35 PM
Vader's Avatar
85,
Adjust the rockers to eliminate the possibility of a detonation sensor problem. You may also discover that the correctly adjusted valve allows more flow and more power.
How is the ignition system? Wires, plugs, distributor cap and rotor, a weak coil, and all the typical items can cause a loss of power and economy.
A little history of the maintenance of the car might be useful.
Later,
Vader
Old Oct 2, 2001 | 07:55 PM
Xenodrgn's Avatar
37 PSI? Isn't it supposed to be 47 (or is that TPI)?
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Oct 2, 2001 | 09:44 PM
Car: 85 Camaro SC
Engine: V6
Hey Xenodrgn, can you take a reading of your fuel pressure.I looked at your sig and saw you have same motor and trans as I do.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
