2 bolt main
Old Jul 31, 2005 | 09:37 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
Axle/Gears: 7.5" 4.10
2 bolt main
i was wondering if anybody would have any info on stroker motors and 2 bolt main's i have a 1989 corvette motor it is a two bolt main and i also have a stroker crank and i was wondering if it will hold up or if i should look for a four bolt block thank you.
Old Jul 31, 2005 | 09:46 PM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
i know tons of people with 2 bolt main small block chevys . i think thay hold up well . in drag cars
Old Jul 31, 2005 | 11:26 PM
zcamaro28's Avatar
Car: 1984 camaro z28 / 1994 jeep wrangler
Engine: 383 stroker / 4.0 HO straight 6
Transmission: built 700r4 / 5 speed
keep the two bolt and if you really want a four bolt then you can get splayed mains thats what we do on our sprint car motors
Old Jul 31, 2005 | 11:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Its not a corvette motor, sorry but they only cam with 4 bolts.
Old Aug 1, 2005 | 05:13 AM
ede's Avatar
ede
hold up to what?
Old Aug 1, 2005 | 08:29 AM
Axle/Gears: 373
I say they '' hold up well '' because some people think just because its a 2 bolt and not a 4 bolt that the mains are going to come flying though the oil pan when you rev it . i am building a 468 bbc for my camaro its a 2 bolt . the motor thats in the car now ...383 is a two bolt and i turn mid 11s with it . never had a problem with it being only a 2 bolt main ....So they Hold up Well!
Old Aug 1, 2005 | 10:20 AM
klumb15's Avatar
not true...i have an 89 vette engine also, 2 bolt main...this is common tho, i've seen huge arguments break out over this...but yea, not all of them came with 4 bolts, i think a very select few came with 4 bolts actually...the majority were 2 bolt mains...2 bolts are stronger than most people think...i've seen 500 hp outta a 2 bolt, and the motor has done fine...
Old Aug 1, 2005 | 03:30 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Are you sure that it actually came from a vette? Did you check the suffix codes and partial vin on the block? I just want to see some actual evidence. It just think that its wierd that everybody and their mother has a vette motor.
Old Aug 1, 2005 | 08:00 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
thanks
thank you all for the help
Old Aug 1, 2005 | 08:09 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
me leigh
and to me leigh sorry to inform you you are wrong about the whole 4 bolt theory but i pulled it from the vette and it has factory aluminum heads with d shaped exhaust ports and guide plates and not to mention the corvette fiberglass valve covers.
Old Aug 1, 2005 | 08:35 PM
klumb15's Avatar
yea, i've seen the vette it came out of....and I also looked up all the block listing/codes, head codes, and checked them all...i also have the aluminum L98 d shaped exhaust ports.....mine was a 305, and it blew up, and we had easy access to the vette motor, so we figured why not...i know what you mean tho, it does seem like tons of people have vette motors...i think alot of people just throw the name on there, or just throw the alum L98 heads on....but if you have a pre87 vette, that doesn't count, thats just like any other stock 350..
Old Aug 2, 2005 | 02:26 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
Guideline I've always heard was that 2 bolts were good up 500-600 peak HP.
Old Aug 2, 2005 | 11:22 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Well some vettes got 305's, so who the hell knows what the did in the late 70's early 80's.
Old Aug 2, 2005 | 11:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm running a studded 2 bolt on my 383. No problems so far.
Old Aug 2, 2005 | 11:41 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you run the aforementioned "splayed" four bolt main caps, the modified block is said to be stronger than a factory four bolt block. The factory four bolts have been known to crack the block between the bolt holes for the main bolts if continually run. Drag racing style "shock load" runs one after the other seem to be the most common cause of death. Apparently long term stock car style runs don't hurt them as bad. Splayed mains are supposed to be better than all of them.
Old Aug 3, 2005 | 09:56 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
If your conserned about the 2bolt mains, and your making less than 600hp, and not spinning it over 7000RPMs, then just get some ARP Main Studs. Go with the ones for a windage tray, bolt up a windage tray to help with oil, and now you have a much better oiling system, and streight in the bottom end that will hold up better than a factory 4bolt main. I have heard that its recomended to get a linehone done on the mian caps when you install studs from the way they load the caps.
If your going all out, then splayed is the way. The idea of going to a splayed main is to keep the mains aligned better with the block, a 2bolt will keep the crank from "falling" out, but keeping proper bearing alignment is more important, and harder to do at higher HP and RPM lvls.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
fasteddi
Sep 10, 2015 09:32 AM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
