what is the right carb and rear for this?
Old Aug 1, 2005 | 02:53 PM
audioslavexxx's Avatar
In a 1985 z28 with a 406 block, and 327 double hump heads i was told a 650 cfm double pumper holley would be a good carb? what do you think? (my quadrajet isnt working very well)
also changing out the 2.73 rear with a 3.42 gears either SLP gears or Richmond or JEGS gears
ALso, can anyone tell me this, the 2.73 rear currently has a Eaton locker. If i use one of the special kits (they have in JEGS) where these lower gears will fit my 2 series carrier, will this locker still work? I believe it should since im not changing my carrier right?
Old Aug 1, 2005 | 03:07 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
personally I'd go a little larger on the carb, but that's just me.
Rear gear selection would depend alot on what cam/tranny/converter you're running and what your intended application is (street, street/strip, or strip only).
Old Aug 2, 2005 | 03:38 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Yeah you're going to need a lot more carb than that. also like stated before gear selction should be based on cam size and what rpm you want to cross the finish line at.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
