nuts and bolts
Old Aug 1, 2005 | 07:20 PM
mightymaro94's Avatar
nuts and bolts
can someone please tell me what size the bolt is that goes into the crank to hold that damn harmonic balancer in place, not the length the thread size, and diameter
thanks i appreciate it
Old Aug 1, 2005 | 07:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Any particular reason you aren't buying a replacement harmonic damper bolt instead of going to the hardware store?
Old Aug 2, 2005 | 05:00 AM
im not goin to the hardware store either, i need to drill the damn bolt hole one size biggerso it can be retapped and i cant find the bolt
Old Aug 2, 2005 | 05:03 AM
ede's Avatar
ede
7/16 fine, forget the pitch
Old Aug 2, 2005 | 07:43 PM
Vader's Avatar
ede is correct (no surprize there). Lucky for you, Chevy used a 7/16-20 bolt in the crank snout. You can retap the hole to a standard 1/2-20 and install a 1/2-20 Grade 5 or better bolt (available at almost any good hardware store).
While you're at the hardware store, try to get a 5-6" length of threaded rod and a couple of mating nuts to pull the balancer back on. Don't use the bolt to pull the balancer hub back on, or you won't be so lucky next time.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
lakeffect2
Sep 7, 2015 03:52 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
