Dissapointing dyno, what else is new?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Not too bad but there is a problem after 5500rpm. The curve hits a flat spot (at 5500) and then drops off around 6500. When I say flat, this thing doesn't fluctuate more then 5hp over 1000rpm. I'm also losing 100lbs of tq in 200rpm. Could be valve float or someone had mentioned that the valves could be too tight. One more thing, not sure if its related, the tq curve was shifted to the left (lower rpm) more than what the dyno guy was used to seeing. Long story short here's the build,
355 holley stealth ram and 58mm TB
30# injectors at ~41psi (the needle was bouncing very fast)
Protopline 200cc
comp cams @ 0.050 230/244* and .544/.576
commander 950pro.
10.18:1 c/r dynamic is around 7.58:1 (low)
and the numbers 355rwhp and 357rwtq I was hoping for closer to 380+. A/f was close to 13:1
I have the dyno files but don't know how to read them. I can send the files to someone if they want to post them for me. I would GREATLY appreciate it.
Protopline 200cc
commander 950pro.
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
You can send them to me MaxxMitchell@kc.rr.com but i wont beable to check my email till after 5 or so, but i could upload the pics tonight, unless you can get someone else to get it for ya.
Are you sure 41 PSI is enough? How much was it bounching, a 1-2 PSI or more? Sounds almost like you where running a little too lean at WOT. Might need to recheck your fuel system, sounds like either a pump or a filter/lines might not be up to par. Checking out the graph will help alot.
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
I still think you needed to jack up the FP and lean out the tables...JM2C! Although I still wouldnt rule out the mechanical side of things!
Engine: 355
Axle/Gears: 4.11
Car: '91 Pontiac Firebird
Engine: 4-bolt 350 TBI w/ Holley ProJection
Axle/Gears: 3.08, 10bolt
definitely a fuel pressure problem if its bouncing around that much, but just out of curiousity, what does the ignition map look like.
Dang, that thing fell on its face...
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Too bad there was not a widebanc O2 sensor available. Looks like pretty good number to me.
Get that problem solved and it will be better yet.
Engine: 355
Axle/Gears: 4.11
There was a WBO2. It was reading 13.1:1
We played w/ the timing and fuel tables but not the pressure.
Car: 87 Firebird
Engine: 5.3 76mm
If you can post the O2 readings vs the RPMs with the HP & TQ graph it might be a little easier to see where theres more power. But i would deffinitly work on your fuel system first and get the pressure evened out. What are you using as a pump, lines, regulator? If its an external pump, did you remove the intake and make a pick up?
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Getting some knock retard maybe? 13.0-13.1:1 afr should have been pretty good if it's stable. 355rwhp isn't out of line IMO, the Protoplines are unported right?
If it's not weak springs yeilding some valve float I'm wondering about some knock retard w/ that wavyness going on if the AFR was steady, the C950 show you KR during the run?
Engine: 355
Axle/Gears: 4.11
Engine: 355
Axle/Gears: 4.11
Today I drove the car and it's now breaking up real bad above 5500. I'm pulling some springs this weekend to check install height and pressure, see if they're the culprit.
Do you think that the motor itself my not like the 14* split in dur. from the intake to the exhaust?
Engine: 355
Axle/Gears: 4.11
One more thing, doing some math ( i know, more bench racing) the car (3440#) went 7.78 @ 89mph. That works out to around 375rwhp.
Engine: 355
Axle/Gears: 4.11
Originally posted by Brian Murray
which is about right if you're making 410 crank HP, considering frictional losses through the transmission & diff.
That's what I thought 375rwhp sounds right, it make sense. 355 OTOH seems low. I'd be happy w/ another 20rwhp.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What kind of fuel pump do you have? Sounds like its time for a better one that can keep up if your having pulsations.
if your using hydraulic rollers its likely valve float, there have been many posts dealing with this. I have afr 190's with the upgrade springs with a comp 224/230 roller and i set my rev limit at 6000 to avoid any chance of float. My power should peak around 5500 with a 383. i think you should peak around 6000 so i can see wanting to get to 6500. I was told by Rick Spearling (owner of afr) that the bsaic spring they sell would float by 5500-6000 with the hyd roller i chose the upgrade i have is good to 6000-6500.
don't rule out FP but its common to have these problems with hyd rollers and off the shelf heads
If the Top line and the Pro Action heads are the same heads, the CHP flow numbers are a good bit lower than the advertised. If that's the case, your numbers look really good to me.
You posted SAE numbers with a smoothing factor of 0. Most magazines and a number of people post the "standard" HP numbers which would probably boost your HP by at least 15 horses. They typically do not use the smoothing factor of 0 either,,, 3 usually, sometimes 5 which typically drop your peak HP by a few horses, but literally smooths the fluctuations in the graph. So, make sure you note those when comparing your numbers.
Your A/F looks good, nothing to suggest you had a fuel problem,, your gauge jumping around could be the gauge. I'd check it out though, because if the fuel pressure really is jumping around you'll need to correct it. Although it might not have any real significant impact on HP, it could extend the life of the engine if the pump is going bad and craps out on you.
The curve is shifted a little more to the left as I would have expected myself. It looks like there might be more than 4 degrees advancement on the cam. Did you degree the cam? If you have the cam advanced more than 4 degrees and throwing a lot of timing at it, it could break up at the top end - backing off the timing would let you know if too much timing is a problem.
More than likely you're getting into valve bounce or float due to the springs - a tell-tell sign is if the rpm it starts to break up keeps getting lower and lower. Try adjusting the lifters to 1/8 turn - if that,,,, and the timing drop doesn't cure things, my bet it you'll need to replace the valve springs.
Engine: 355
Axle/Gears: 4.11
I pulled off a couple springs and will be taking them to get tested today. If that's not it, I'll bump up the FP and adj. the valves 1/8 turn or less.
Thanks for everyone's help.
Car: 79 Camaro RS
Transmission: TH350
BTW, these are none corrected #s. "standard" and there is only a difference of about 8 hp versus the SAE corrected #s. Remember, this was with less timing IIRC, the 6th pull you added timing and a little fuel where you were lean from the 005 pull, and your numbers dropped...correct!?
DYNORUN.005: 102.64°F 30.09in-Hg Humidity:8% STD:1.02 Average Gear Ratio:N/A
s mph hp Air/Fuel
0.18 59.00 N/A 11.71
0.34 60.00 198.60 11.88
0.45 61.00 205.58 12.31
0.56 62.00 210.88 12.53
0.67 63.00 216.88 12.61
0.78 64.00 221.92 12.60
0.88 65.00 226.49 12.55
0.99 66.00 231.60 12.52
1.09 67.00 236.13 12.51
1.20 68.00 241.47 12.48
1.30 69.00 246.33 12.46
1.41 70.00 250.73 12.44
1.51 71.00 255.39 12.41
1.61 72.00 260.58 12.39
1.72 73.00 264.77 12.38
1.82 74.00 267.81 12.35
1.92 75.00 271.66 12.32
2.02 76.00 275.60 12.32
2.13 77.00 279.88 12.37
2.23 78.00 284.15 12.43
2.33 79.00 288.71 12.48
2.43 80.00 292.42 12.52
2.53 81.00 296.21 12.57
2.64 82.00 300.68 12.61
2.74 83.00 304.23 12.62
2.84 84.00 307.58 12.62
2.94 85.00 311.59 12.64
3.04 86.00 314.50 12.67
3.14 87.00 317.34 12.69
3.25 88.00 321.13 12.69
3.35 89.00 324.26 12.69
3.45 90.00 326.89 12.69
3.55 91.00 329.08 12.69
3.66 92.00 331.74 12.68
3.76 93.00 333.94 12.68
3.86 94.00 336.60 12.66
3.97 95.00 338.20 12.68
4.07 96.00 340.88 12.73
4.18 97.00 344.38 12.79
4.28 98.00 347.10 12.83
4.39 99.00 350.02 12.87
4.50 100.00 353.27 12.91
4.60 101.00 356.65 12.96
4.71 102.00 357.74 12.99
4.81 103.00 360.88 13.02
4.92 104.00 361.98 13.03
5.03 105.00 364.04 13.03
5.14 106.00 363.21 13.02
5.25 107.00 363.29 13.00
5.36 108.00 363.49 13.02
5.47 109.00 363.10 13.05
5.58 110.00 363.50 13.09
5.70 111.00 364.51 13.14
5.81 112.00 364.10 13.15
5.93 113.00 364.64 13.13
6.04 114.00 364.00 13.02
6.16 115.00 361.55 12.89
6.28 116.00 360.61 12.83
6.40 117.00 359.38 12.74
6.53 118.00 356.01 12.55
6.65 119.00 355.08 12.01
6.78 120.00 347.78 11.38
6.92 121.00 313.37 10.93
MAX: 6.92 121.00 364.64 13.15
MIN: 0.18 59.00 198.60 10.93
DYNORUN.006: 102.06°F 30.10in-Hg Humidity:8% STD:1.02 Average Gear Ratio:N/A
s mph hp Air/Fuel
0.22 51.00 N/A 10.90
0.44 52.00 153.23 10.72
0.57 53.00 160.27 11.31
0.69 54.00 166.29 11.84
0.80 55.00 173.80 12.14
0.92 56.00 179.16 12.30
1.04 57.00 183.45 12.33
1.15 58.00 188.31 12.31
1.26 59.00 192.91 12.27
1.38 60.00 198.06 12.23
1.49 61.00 204.14 12.21
1.60 62.00 209.06 12.20
1.71 63.00 214.39 12.21
1.82 64.00 219.56 12.24
1.92 65.00 224.17 12.26
2.03 66.00 228.94 12.26
2.14 67.00 234.19 12.22
2.24 68.00 238.55 12.22
2.35 69.00 243.48 12.28
2.45 70.00 248.22 12.31
2.56 71.00 252.67 12.27
2.66 72.00 257.18 12.24
2.77 73.00 261.91 12.24
2.87 74.00 266.24 12.25
2.97 75.00 270.89 12.28
3.07 76.00 274.83 12.31
3.18 77.00 278.75 12.33
3.28 78.00 282.55 12.35
3.38 79.00 286.88 12.38
3.48 80.00 290.89 12.42
3.59 81.00 294.61 12.48
3.69 82.00 298.78 12.55
3.79 83.00 303.11 12.58
3.89 84.00 307.17 12.57
3.99 85.00 309.93 12.58
4.10 86.00 313.03 12.62
4.20 87.00 316.79 12.65
4.30 88.00 320.56 12.66
4.40 89.00 322.22 12.66
4.51 90.00 323.69 12.63
4.61 91.00 326.33 12.60
4.71 92.00 329.03 12.59
4.82 93.00 330.71 12.59
4.92 94.00 332.76 12.62
5.03 95.00 336.04 12.64
5.14 96.00 339.37 12.63
5.24 97.00 341.40 12.64
5.35 98.00 344.02 12.68
5.45 99.00 346.52 12.74
5.56 100.00 348.78 12.77
5.67 101.00 352.41 12.79
5.77 102.00 354.50 12.82
5.88 103.00 356.08 12.84
5.99 104.00 358.13 12.82
6.10 105.00 359.71 12.79
6.21 106.00 360.39 12.77
6.32 107.00 360.08 12.78
6.43 108.00 359.94 12.82
6.54 109.00 360.16 12.86
6.66 110.00 359.91 12.86
6.77 111.00 360.37 12.83
6.89 112.00 359.82 12.80
7.01 113.00 360.58 12.76
7.12 114.00 357.82 12.71
7.24 115.00 356.48 12.67
7.37 116.00 356.71 12.66
7.49 117.00 354.27 12.59
7.61 118.00 351.67 12.45
7.74 119.00 351.93 12.20
7.87 120.00 347.17 11.80
8.00 121.00 333.71 11.13
8.15 122.00 298.87 10.60
8.31 123.00 275.90 10.45
8.48 124.00 263.95 10.89
MAX: 8.48 124.00 360.58 12.86
MIN: 0.22 51.00 153.23 10.45
s mph hp Air/Fuel
s mph hp Air/Fuel
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You didn't mention it being 102* when you were dynoing. I'm sure that's good for 1-2% more power.
Something seems off with that fuel pressure still. Why do you have it set to 41psi anyways? I'd set it to at least 43, maybe something more like 45-47, and then just raise the injector constant in the chip, see if that fixes anything at all.
Car: 88 Camaro SC
Engine: SFI'd 350
Engine: 355
Axle/Gears: 4.11
It seems to be running a tad rich the way it is across the whole board.
FP, I think I am going to set it at 45psi even though it isn't going lean. Piece of mind.
Poorboy8, Yes. On run 6 we tried adding a bit more timing and the numbers did go down, not much, but they sure didn't improve. I don't think we changed the fuel from dyno 5-6.
Engine: 355
Axle/Gears: 4.11
Car: 79 Camaro RS
Transmission: TH350
I'm running a C950 ECU from holley which doesn't recognize injector size. There is no place in the ECU to change the constant. It's all done w/ the fuel table.
Although do you remember weither or not you can your duty cycle on your injectors? Thread Starter
Engine: 355
Axle/Gears: 4.11
New Information.
Got the springs checked out,
130# on the seat
325# over the nose.
Damn near coil bind though, less than .080". Any votes on valve float? My machinist said I should be looking at something w/ around 380# open.
Problem is finding a spring w/ an install height of 1.750
130# on the seat
325# over the nose.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
According to comps catalog, for your cam you should be using a 987 dual spring: 121@1.800, 388@1.200. Your machinist can probably get an offset retainer or whatever is needed to get these to fit. This is also a 1.430" spring, what size is in there now? I would call comp and get their opinion.
Engine: 355
Axle/Gears: 4.11
Comp keeps telling me to go w/ the 918's which is 130 and 318. That just doesn't sound like enough to me at open.
The springs I have cam on the heads from summit and were supposed to rated to .600 lift but didn't give me any pressures at open and close.
Will running a different retainer like that screw w/ my valvetrain geometry? Would it req. longer pushrods?
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
been there done that. What's in the tank??
