Help with this stupid miss...
Old Aug 6, 2005 | 02:09 PM
jamr0d's Avatar
my car has carried a miss from its old engine to the new one. it happens when the engine is under load at around 3K, but it doesn't do it every time i drive it. The tach jumps pretty bad for a couple of seconds then it smoothes back out. The car has a new distributor, cap, rotor, coil, plugs and wires. so i was thinking maybe it's an injector sticking, but i've tried injector cleaner and saw no change. I also don't have an air pump and have headers w/o air tubes, but i still have my egr. I don't know if this could be the source of the problem. Any ideas would really be helpful.
Thanks in advance
ahh yeah.. tpi 350
Old Aug 6, 2005 | 05:38 PM
Vader's Avatar
Check the condition of the ignition primary power wiring. That would include the ignition switch and power from the fuse panel or fusible link, depending on the vehicle the engine is in. I just went through this with a '57 Bel Air.
Old Aug 7, 2005 | 02:18 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Another good thing to check would be the wiring going to the Distributor to make sure it isn't rotted or anything. You could also clean the contact points for the wiring too.
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
