Recall question
Old Sep 17, 2001 | 10:11 PM
DrStampede's Avatar
Recall question
Does anyone know if the recall for the 91/92 camaro/firebirds is still in effect. mostly the one about the gastank.
NHTSA Campaign Number : 94V077000
Year : 1992
Vehicle Make : CHEVROLET
Vehicle Model : CAMARO
Summary :
THE FUEL FILLER NECK SOLDER JOINT CAN DEVELOP CRACKS OR PIN HOLE LEAKS, WHICH
DOES NOT COMPLY WITH FMVSS NO. 301, "FUEL SYSTEM INTEGRITY." THE CRACKS AND
HOLES CAN ALLOW FUEL VAPOR AND FUEL LEAKAGE.
CONSEQUENCE OF NON-COMPLIANCE: GASOLINE VAPORS AND FUEL LEAKS CAN RESULT IN A
FIRE IF EXPOSED TO A SOURCE OF IGNITION.
DEALERS WILL INSPECT THE FUEL TANK ASSEMBLY AND REPLACE THOSE WHICH EXHIBIT THE
CRACKS OR PIN HOLE LEAKS.
SYSTEM: FUEL; FUEL TANK ASSEMBLY; PIPE; FILLER; NECK; FMVSS 301.
VEHICLE DESCRIPTION: PASSENGER VEHICLES.
I've smelled gas ever since i got the car now its getting really bad anyone know of someone that might help especally since GM doesn't want to help me on this one
Chris - 92 RS, 89/85 IROC-Z 1LE
* You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you protect it like it's your family, then you drive it like you stole it!
Old Sep 17, 2001 | 10:32 PM
tacoboy's Avatar
a recall is a recall...if something is unsafe it will continue to be unsafe and gm realises this, or maybe that was just the dealership i worked at's motto but i doubt it cause they are cheap. anyway my point is at least at this dealership (unlikely that it is their policy and not gm's) a recall is good forever.
Old Sep 18, 2001 | 12:26 AM
Arawn1's Avatar
<font face="Verdana, Arial" size="2">Originally posted by DrStampede:
</font>
I don't know about you guys, but the first thing I do when I buy a used car is take it to a dealer and have them run the VIN number through the computer. If there are any recalls that haven't been done for the car they'll book an appointment to get it done for you.
My '86 Firebird needed the seatbelt job done... Had to wait about 1 week for them to get the parts in but they took care of it no problem.
Arawn1
[EDIT] A recall is a recall. They *must* do the required work for *free* or have your lawyer remind them of this. Try phoning another dealer's service dept and giving them the VIN # to see if there are outstanding recalls. If there are, they can give you the campaign numbers. I think the only way they can refuse is if the car isn't safe to put on a hoist (in which case, a fuel leak is the least of your worries )
[This message has been edited by Arawn1 (edited September 17, 2001).]
Old Sep 19, 2001 | 11:08 AM
Jcpstrat's Avatar
My 91 is going in for this check tomorrow and I'll let you know what they say.
Old Oct 7, 2001 | 09:22 PM
Jcpstrat's Avatar
The Pontiac dealership wouldn't inspect my car for free because a previous owner had already had the tank replaced under the recall.
Turns out I have a defective gas cap that is allowing fuel to spill out when tank is full, when I take left turns and is also venting fumes.
GTAman
Mar 15, 2019 11:40 AM
Eric2ndGen
Aug 31, 2015 11:30 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
