MAF power and burnoff relays
Old Oct 5, 2001 | 10:58 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Quickly, are the part numbers for the MAF burnoff and MAF power relays the same? are they identical? Can anyone take a look and give me the part #'s for them real quick?
Lastly, where are they located? Drivers side firewall or passenger side headlight?
Thanks!
'89 TA - 5.7 TPI (L05, was originally a 305TPI), T5-WC, 3.08 Posi (Drum)
Old Oct 5, 2001 | 11:36 PM
drive it's Avatar
[QUOTE]Originally posted by Mangus:
[B]Quickly, are the part numbers for the MAF burnoff and MAF power relays the same? are they identical? Can anyone take a look and give me the part #'s for them real quick?
Thanks!
There's been a lot of discussion about the part #'s being diff. for the power and burn off relays, but bottom line is-most auto parts stores list the same #'s and the same relays will work fine. As for where they are on your car I dunno-sorry! I'm an '86 Vette!
86 406
Old Oct 6, 2001 | 12:41 AM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Well don't know the part numbers but on a 89 L98 its the middle one on the drivers side. I think the other one is the first one on the drivers side too.
Old Oct 6, 2001 | 02:23 AM
Mangus's Avatar
Transmission: T5WC
Thanks! Can anyone confirm?
There are 3 against the firewall on the drivers side. im guessing the two closest to the fender are MAF (but which is which) and one is fuel pump. Can someone confirm which is which on an '89 Trans Am?
Old Oct 6, 2001 | 04:22 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
As they are very inexpensive and share the same part number renew both of them!
Old Oct 6, 2001 | 07:47 PM
camaro6spd's Avatar
all right, i just replaced mine(burn-off) and it is the one closest to the fender on a 87 camaro and the one all the way to the pass. side is the power, mine even says in red letter, MAF Power. The relays cost 11.87 at Car Parts F/X in NJ.
Old Oct 7, 2001 | 06:39 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
according to Painless Wiring they have two different part#s
MAF burnoff-#10094701
MAF Power-#10067925
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
www.gcfba.com (Greater Cincinnati F-Body Association)
http://www.cincyspeed.com/
Old Oct 7, 2001 | 10:05 PM
Mangus's Avatar
Transmission: T5WC
What year are those part #'s? I've got an '89
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bert87
Aug 23, 2015 03:50 PM
