How much $$ are we talkin
Old Oct 8, 2001 | 03:30 PM
BowtieFever's Avatar
What would be a good price for a shop to put install a different speedo gear?
92 Camaro RS
305 TBI
T-Tops
DynoMax Cat-Back Exhaust
Gutted Cat
Hypertech Street Runner Chip
Custom K&N open element cold air intake
Custom Interior
Window Tint
JVC El-Kameleon Head Unit
Pyramid 6 x 9's
Jensen 5 1/4's
2- 10" Kenwood Tornado Subs
Pyramid 600 Watt Amp
Best ET: 15.976 @ 86.01 mph
reaction time: 0.479
60 ft: 2.269
Old Oct 8, 2001 | 06:57 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I'll say at least $100. You would probably have to remove the tranny. I'm not sure which gear requires removal of the tail-shaft, but if that happens then the price goes up.
Either do it yourself or wait until you need to get other work done (clutch, etc) before you do the mod.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Oct 9, 2001 | 09:54 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You do have to remove tail shaft which isn't that hard. You can do it yourself. There is a tech article on this board somewhere for it. Just be careful of the little spring clip that holds the gear in place on the output shaft. I broke mine (despite the warnings in that tech article) and had to get one from a local tranny shop. Essentially remove drive shaft and torque arm. then take the 4 bolts out of the tail shaft housing and remove it. Change gears and reinstall. Took me all of an hour to do.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Oct 9, 2001 | 01:39 PM
brharris27370
What kind of difference did you notice from gears. Just wondering if modification is worthwhile.
DISTURBthePEACE
Jun 23, 2002 04:18 AM
DISTURBthePEACE
Jun 5, 2002 08:43 PM
Bluebird
May 25, 2002 03:01 PM
PullmeoverRed
Feb 8, 2001 06:41 PM
GeneralHazzard
Jan 6, 2001 10:10 AM
