speedo sticks, clicking noise when accelerating
Old Oct 8, 2001 | 07:34 PM
britered86transam's Avatar
i have and 86 WS6 trans am, my first qeustion is: just recently when i start my car and begin driving, my speedometer will stick in one spot for about 5 mins, whut could be casueing this?
my second question: when i accelerate i hear a clicking sound coming from the car, whut could this be?
thanks
Old Oct 8, 2001 | 11:25 PM
Vader's Avatar
86,
Both could be caused by one problem. Even though you have a VSS on your car, the '86 model still uses a speedometer cable. The cable is either fraying in the housing or is damaged at an end. You can get a speedometer cable repair kit at many parts sources.
The ticking you are hearing could also be the cable wrapping up in the outer housing. Repair the cable first and see if the noise continues.
Incidentally, are you also getting a "SES" lamp on your dash? A code 24, possibly?
Later,
Vader
Justice and Freedom will Prevail
Adobe Acrobat Reader
Old Oct 8, 2001 | 11:31 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
yeah i have this same problem, the tapping sound increases with the rpms. sometimes it goes away, sometimes its there, but it really bothers me. im going to check my speedo cable, is there any other possibilities?
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
Old Oct 9, 2001 | 09:13 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i would say u need a new speedo gear or cable in your tranny and for the noise my best guess would be an exhaustleak somewhere. check the exhaust manifold and wehre it bolts onto the pipe and the y portion of the pipe. otherwise it might be a stuck lift or valve.
Old Oct 9, 2001 | 11:03 PM
MrsLottaBallsCamaro's Avatar
Thank *** I'm not the only person that stupid clicking sound is happening to! I've been meaning to check that speedo cable.......In my last car, I got a clicking sound, and it was the freeking water pump dying.
GTAman
Jul 3, 2024 07:29 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Randomtask2
Sep 7, 2015 05:06 PM
