Throttle bracket for a Q-jet/700R4 combo...what year thirdgen for this combo?
Old Oct 8, 2001 | 05:27 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I pulled my 305/TBI out and installed a 400sb switched to a Q-jet also. I still have a 700R4. I need the bracket for throttle cable, TV cable, and cruise control cable. If anyone has a gm part number for this piece let me know. I know some early thirdgens had a Q-jet and a 700r4 but exactly which year? This way the dealer can get me a part number in case no one here knows. Thanks
  • 412ci/sb
My Homepage
Old Oct 8, 2001 | 05:42 PM
irocbsa's Avatar
I believe that 84 through 87 offered the Carb/700 combo. Not sure about 83. I don't think the 700 was in the Fbody then. I'm gonna go check.
bsa
Edit: The Carb/700 combo was available from 83 to 87. Just go to the dealer and snag on e from 87 or whatever year suits you.
[This message has been edited by irocbsa (edited October 08, 2001).]
Old Oct 8, 2001 | 06:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can get one out of any vehicle with a 305 and a 700, which includes LG4 Caprices from the mid 80s, a far more plentiful thing in the boneyard; in fact, it may be that any GM V8 with a 700 would use the same bracket... I can't see why they couldn't.
ICON Motorsports
Old Oct 8, 2001 | 10:07 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
So should my bracket from the 305 work as well? I will give it a shot. Has anyone else switched to carb with a 700-R4
Old Oct 9, 2001 | 01:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not very familiar with TBI, but the q-jet bracket mounts onto the intake manifold. I'd think you'd have more of a mismatch in the length of those cables; i.e., the distance from the bracket to the throttle shaft of a TBI being different than that on a q-jet. Certainly was the case in the days of 2bbl vs. 4bbl.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 9, 2001 | 03:14 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
The TBI did come with a bracket for all three cables. It looks like a tower. It does bolt to the manifold. back drivers side. If all it needs is moved foward some to reach the new cables I should be able to make it work. I get my Q-jet back tommorow and I will go from there.
  • 412ci/sb
My Homepage
Old Oct 9, 2001 | 11:53 PM
speedfreaker's Avatar
hay i got a 700r4 and the 305 its on my 83 try a junk yard i also found one at the parts store hangen on the wall
CHRIS
1983 firebird transam
edelbrock performer rpm intake 360*k&n intake 160 theroostat gitting trans raced up and lots and lots of plans 4 the future
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
