How do I set the base timing
Old Oct 9, 2001 | 11:46 AM
94'_SS's Avatar
I have a TBI 305 and was wondering the in's and out's of seting the base timing. What should it be set to? How hard is it on a scale of 1-10? Thanks for the help, any pics of the process would be appricated.
Old Oct 9, 2001 | 02:43 PM
ede's Avatar
ede
just unplug the est and set the timing like you would on anything else ,make sure you plug the est back in when you're done.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 9, 2001 | 03:05 PM
94'_SS's Avatar
Which wire is the est wire and what should the timing be set at? I no longer have any of the stickers to tell me were the timing should be set to. Do I start the car then unplug the est wire or do I unplug the wire before I start the car or does it even matter? How can I clean the marks I am suppose to be reading and do they have numbers on them such as 0-5-10 degrees?
Old Oct 9, 2001 | 04:33 PM
z28dan's Avatar
The wire you are looking for is brown in color and is located in the bundle of wires near(above)the blower motor. I unplug the brown wire before starting the car, you will get a service light. I believe your base timing should be at 6 degrees. To clean your timing marker, use you finger or something. I think 6 degrees is the valley after the largest mark, I could be wrong.
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Oct 9, 2001 | 06:37 PM
breathment's Avatar
can't u just connect the A&B diag. terminal
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 9, 2001 | 07:58 PM
NTChrist's Avatar
Base timing for a 305 TBI should be 0*. Sounds funny, but the prom will move it to something more useful once the est is plugged back in.
Some people move the base timing to a few degrees advanced, if they need it.
No guts, no glory.
Old Oct 9, 2001 | 11:42 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Once timing is set and the est is plug together, disconnect the battey for a few seconds to erase the code set by disconnecting the est.
Old Oct 10, 2001 | 07:31 AM
94'_SS's Avatar
Thanks for the help, my est wire was cramed behind the wiring harness in front of the heater box where I could not see it. Set timing and the car runs much smoother at idle.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
