Oil pan braces?
Old Aug 12, 2005 | 11:56 PM
Mechanix's Avatar
Car: 1985 Camaro Berlinetta
Engine: 305 sm block chevy
Oil pan braces?
The stock oil pan came with two metal braces that ran the length of the oil pan on each side? I have an aftermarket chrome plated oil pan and I'm wondering if the braces should go back on when I install it?
Old Aug 13, 2005 | 06:37 AM
ede's Avatar
ede
doesn't really matter, but be better if they did. they'er used to prevent the bolt holes from distorting.
Old Aug 13, 2005 | 02:59 PM
Mechanix's Avatar
thnx but there is another twist. The part of the brace that is around the dipstick hole doesn't fit in the grooves of the oil pan
Old Aug 13, 2005 | 04:43 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Then the answer would be a "no". They don't help in sealing the pan anyway. Actually had better luck without them.
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
