New problem
Old Oct 10, 2001 | 10:00 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
New problem
Thanks again who responded to me 'Stranded at school' thread. However when I replaced the starter I noticed a trail of oil coming down between the flywheel and the trans pan. Rear main right? How hard are these things to install? Im sure the main problem is getting the trans off. The leak is pretty small right now, but it will only get worse.
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Oct 11, 2001 | 07:12 AM
ede's Avatar
ede
be best to find out for sure where it's coming from instead of guessing. could be several other things leaking, oil sender, intake, valve cover, front pump seal.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 11, 2001 | 11:53 PM
Guest
Guest
Posts: n/a
I had a small leak on mine and never did fix it... 7 years later it didnt get any worse. Maybe you will get lucky, or maybe its not the rear main like ede said.
Old Oct 12, 2001 | 02:27 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You'd have to drop the tranny.
At least you have the 1piece, if it were the 2 piece you'd have to drop the tranny, pull the motor, oil pan, and rear bearing cap.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
