mystery heads 333882
Old Aug 17, 2005 | 11:31 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey i came on to a set of heads for small chevy with 1.94 intake valves. the casting number on the heads is 333882 and i cant find anything in my books about them, anyone have any clues??
Old Aug 17, 2005 | 11:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
No particular mystery.
http://www.mortec.com/castnum.htm
333882.....74-80...350/400......76cc chambers
Basically large chamber, low compression, smog-era heads.
Old Aug 17, 2005 | 11:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Almost certainly cracked too.
Old Aug 17, 2005 | 04:39 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i got them for free at work, so no complaints there. Are these doable for performance purposes? I allready have to get them machined and everything to use them so i could gain some compression there and then also on the piston side of things i could gain alott. looking for 10.00-10.50 to 1 in the finished product.
so if i total 650 bucks in work would they come out ahead of vortecs??
Old Aug 17, 2005 | 04:55 PM
five7kid's Avatar
No way, no how. To get 10:1 CR would require domed pistons. Flow and chamber design all favor Vortecs.
You got your money's worth with those heads. David Vizard apparently likes them, but something tells me you don't have his budget.
Old Aug 17, 2005 | 07:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If I had to use a smog head, there are much better factory castings to pick from. As mentioned above, they're probably cracked. 882 castings are a very thin casting and prone to cracking.
Old Aug 17, 2005 | 10:28 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
At least the price was right.
Worst of the worst.
Give them away to someone else that wants to go slow(er).
Find a small chamber hi perf casting.
Old Aug 18, 2005 | 11:40 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
wow k, well i guess no harm no foul huh?? thanks alott!
Old Aug 18, 2005 | 12:44 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Those may not be cracked. The larger valve versions of those heads like to crack between the seat areas. I wouldnt try and put bigger valves on them and dont waste too much on them. Save your money for something better.
Old Aug 19, 2005 | 11:08 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
yea im not going to screw with them..
Old Aug 19, 2005 | 02:19 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
That will get you a brand new set of vortecs from Scoggin Dickey with the spring seats and valve guides already machined to accept more lift. You could then do a mild port job to clear up the pockets and gain a little more. Best bang for your buck.
Old Aug 19, 2005 | 10:20 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
There's a guy in the classifieds on www.sethirdgen.org selling a set of slightly used World Products SR torquers cheap as of 8-19-05. Like $300 and they are complete with good springs and everything.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
