Is This True??
Old Oct 13, 2001 | 10:18 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is This True??
I was in autozone the other day and heard an announcement on the radio about if parked on a steep incline to use the E-brake of course, but mine doesn't work, but they also said to park the car in reverse. Would this be a good idea.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 13, 2001 | 10:45 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
...they also said to park the car in reverse.
</font>
Not if it's an automatic.
But for standards, often the reverse gear has a higher ratio than 1st and less prone to "rolling". But this was more appicable 20 years ago. Today's newer trannies often have steeper 1st gears, so you may be better off in 1st.
Having a working E Brake engaged further reduces tendency to roll along with turning your front wheels into the curb (based on direction of roll) if one's available.
Where I live, IF you car should accidentally roll down a hill, you can be "charged" if your E Brake was not engaged.
[This message has been edited by Glenn91L98GTA (edited October 13, 2001).]
Jason M 91Z's Avatar
Only if its a stick. Keep putting yours in park like you're supposed to.
-Jason M. 1991 Camaro Z28
Old Oct 13, 2001 | 10:53 AM
Car: 99 Formula
Axle/Gears: 342
Thanks, I guess I missed that part of the announcement.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Oct 13, 2001 | 11:30 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jason M 91Z:
Only if its a stick. Keep putting yours in park like you're supposed to...
</font>
...AND use the parking brake. I have a couple of manuals, and I always park in neutral with the park brake firmly applied. I haven't lost one yet. I avoid parking in gear unless I'm on a very steep incline/decline. One of those phat SUVs trying to squueze into a subcompact parking space may bump you a bit. If the car is in neutral, you buff or repaint the bumper cover. If the car is in gear, you buff/repaint the bumper cover, and may have to replace 'U' joints, driveshafts, transmissions, etc. Then again, I can get pretty **** about stuff like that.
Later,
Vader
Justice and Freedom will Prevail
Adobe Acrobat Reader
Old Oct 13, 2001 | 01:28 PM
The only time I use my e-brake in my automatic car is when parked on a hill, so I don't load the tranny and have to pop it back into gear.
[This message has been edited by Jason M 91Z (edited October 13, 2001).]
Old Oct 13, 2001 | 03:04 PM
JETHROIROC's Avatar
I apply the parking brake on all cars in any situation. I can't think of any compelling reason not to use it all the time as extra insurance other than pure laziness. Kinda like buckling the seatbelt to me.
Having a master cylinder fail before, I also am annoyed by people that don't tighten the parking brake periodically as you may REALLY need it one day .
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 13, 2001 | 09:01 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Using your parking brake also keeps the rear brakes adjusted properly. If you dont use it often enough the adjusters will probably seize up.
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
