Will 22lbs injectors support this?
Old Oct 11, 2001 | 09:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just bought brand new MSD 22lbs injectors last year and now i've decided to upgrade the motor and I'd like to know if I'll be ok. I got TF Heads a 218/224 495/502 112 cam and a highflow tpi unit. Msd said the injectors will support 50 PSI and 400 HP. Do I have to upgrade to the 24's. I just paid an arm and a leg for the 22lbs.
Old Oct 11, 2001 | 10:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
For 400 HP, you would need 25# injectors @ 42 psi. However this is at 100% duty cycle. You should never exceed 80% duty cycle, which means you will need around 30# @ 42 psi.
22# injectors @ 42 psi = 24# @ 50 psi. The key is at what psi are the MSD's getting their rated flow.
Old Oct 11, 2001 | 10:07 PM
rezinn's Avatar
Glenn, you mean 22# at 50psi = 24# at 42psi?
Old Oct 11, 2001 | 11:19 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Which TFS heads? 23* ? Your new combo sounds a lot like my current setup..... Anyways, the short answer is no, 22 lb injectors will not support that kind of power with that combo. I know because my 22lbs @ 51psi were not keeping up on the high end and were causing some serious lean conditions at part throttle and idle applications. So I bought some 30lb SVOs and am running them @ 43psi with pretty good results..... Unfortunately my EEPROM burning facilities have failed me at the present so I still have some issues with my setup...... Even without a solid EEPROM to work with the injectors, my car runs much smoother.....
Good Luck....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 12, 2001 | 07:28 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Hey you guys,
When your brand new 22# injectors dont work, let me know, I need a set of 22# injectors.
Cheers
Richard
Old Oct 12, 2001 | 09:18 AM
92zeddar's Avatar
well how come I seen in a super chevy magazine where stock 305 fuel injector 19# made 400 horse??
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Ram air
305 5 speed, underdrive pulleys and TB by pass
Old Oct 12, 2001 | 09:37 AM
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by 92zeddar:
</font>
For how long before they toast it?
The calc for determining fuel injectors required are:
HP = Inj Flow x 2 x.8 (duty cycle) x # cyls
or
Inj Flow = HP / (2 x .8 (DC) x # cyls)
Obviously if you want to run at a Duty Cycle higher than 80%, you can run smaller injectors. But you are asking for problems.
To determine the "new flow equivalent for a given PSI, the formula is:
New Flow = (New PSI/Old PSI)^.5 x Old Flow.
But remember that raising fuel pressue only equates to the higher flow at low vacuum (ie. WOT). The effects of raising fuel pressue via an AFPR has minimal effect at idle due to the vacuum affecting the Fuel Pressure Regulator.
Old Oct 12, 2001 | 06:52 PM
Matt87GTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
But remember that raising fuel pressue only equates to the higher flow at low vacuum (ie. WOT). The effects of raising fuel pressue via an AFPR has minimal effect at idle due to the vacuum affecting the Fuel Pressure Regulator.</font>
Exactly. Thinking that way about how much maximum power an injector will support will lead to some serious driveability issues, like Glenn says....... I know - I had them...........
1987 GTA L98 MD8
My GTA
Old Oct 14, 2001 | 12:33 AM
1BadAzzGT's Avatar
I have a set of 30# injectors and have just upgraded to 42#'ers They would be enough I would think. Let me know if you're interested.
Founder, Tealnet.Com
'98 Mustang GT
My 98 GT
Mods: Vortech S trim, 42# inj, 5.4 Heads (ported/polished), custom ground cams, 99 intake, ATI 3 corer intercooler, Walbro 255 intank pump, Walbro 255 inline pump, Aeromotive adjustable fuel pressure regulator #13102, NO FMU!, Steeda Tri-Ax shifter, Steeda heavy duty LCA's, Steeda heavy duty UCA's, Steeda Chrome Moly subframes w/cross-brace, Steeda Cobra R hood (2 1/2" cowl), BBK 75mm TB, Pro M 80mm MAF, Eibach progressive springs, K&N Air, Cobra "R" rims, 31 spline Moser axles, SVO differential, Downs rear Girdle, FMS 3.73 gears, Cobra floor mats, Cobra leather shift ****, "A" pillar (Phantom White Gauges and custom gauge pod), Steeda race pedals, Mac offroad "H" pipe, hi-flo cats, and Borla XR1 catback.
Dyno #'s: 298.2rwhp/332.8rwtq (running rich 9:1 a/f)
Best ET to date: 13.42@104.91 (Temp F: 109 Humidity: 38 Barometer: 28.90) See the run on video!
Mods not installed: 3 core intercooler, ditching the FMU!
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
