Water in my engine, for a LONGGG TIME! Help!!!
Old Aug 21, 2005 | 09:50 PM
89 CamaroIROCZ's Avatar
Haven't been on the boards in awhile, finished up college. I knew water got in my engine a couple of years ago, alot of it, thought my car cover was water proof, to my dismay it wasn't! Figured the engine was toast. Pulled it today and took the oil pan off, no rust at all on anything. Took the heads off and the same. There was about a gallon of water in there but it was never run with the water inside of it. Anyways, how do I go about cleaning all that milkshake out of all the rotateing assembly? I was thinking about taking everything out piece by piece and cleaning it with some sort of cleaner and reinstalling them with engine lube, pistons, rods, bearings, crank, etc. What cleaner would you recommend, and is this the way you'd recommend to do it? There is just a ton of gunk on everything.
Matt
Old Aug 22, 2005 | 01:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd take some degreaser and a pocket full of quarters to the carwash.
Might want to fashion up a stand with a screen on it for smaller parts.
Old Aug 22, 2005 | 08:03 PM
any other opinions on the subject? Is it smart to hose down my engine internals? Or worse to add degreaser inside of an engine?
Matt
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
